Old 04-23-2008, 09:41 PM   #1
njk53
Default Transmission Mount
What are you guys using for a transmission mount? Would you use a polyurethane mount or would a stock rubber mount be OK? Comments?
Old 04-23-2008, 10:34 PM   #2
ss3011
ss3011's Avatar
Liked 238 Times in 113 Posts
Default Re: Transmission Mount
Either one will work, just don't use a solid mount.
Old 04-24-2008, 08:44 AM   #3
T Ketels
In my experience, when I ran a urethane trans mount with solid engine mounts, I busted cases in the bellhousing area. Since I went to the cheapest stock ones, I haven't had a problem.
Tim
T Ketels is offline   Reply With Quote
