What can I do to keep the front end from shaking the steering wheel out of my hands after a wheelie? First time out leaving off the t-brake Saturday, when the front end would drop it would just about shake the steering wheel out of my hands. I have been told my front end alignment isn't set up properly. Any ideas on where to start?
#2 | |
http://www.edquay.com/camaro/82-92camaro_catalog.pdf |
Liked 886 Times in 238 Posts
Also ,it would be wise to install Ed's tie rod kit. ......It makes a major improvement in the bump steer. .....The damper is a must have on this front end. ....Tom
Liked 165 Times in 59 Posts
had this issue with my 80 big block camaro,front end comes up with the tires off the ground,tires are not rotating,when you car comes down it may be coming down not level,more than likely the right would hit first(pulling the wheel right)then the left would hit(pulling the wheel left),even if you install a steering damper it mite still jerk the wheel,do you run the stock rear sway bar? does the car drive good other wise gmonde
The car drives good otherwise, and I am running the factory rear sway bar. I've seen cars wiggle the front wheels a little when they come down, but this thing felt like it was doing the same thing funny cars do after the burnout sometimes. It never did this until it started pulling the whels a good bit. I see stockers and super stockers doing giant wheelstands, but look just fine after they come down. Are they all using the Dampner?
Liked 231 Times in 107 Posts
Stephen,
I'm not sure where your located but, in Dayton, Ohio is a racer by the name of Richard Doane. He's one of the best on front ends in this part of the country. I don't have his number but I'm sure someone on here will. He also races a Camaro about that same year. |
#7 | |
Liked 804 Times in 168 Posts
The exact same thing happened to me 20 years ago when I put my 86 camaro together. Put a damper on it is all you need to do. If you can fabricate a little just get a damper from a volks bug and adapt it to the drag link. it is easy to do.
Dave Casey 1330 STK |
I can do some fabrication, Anybody have a pic of one installed? Should I be attaching one end to the drag link and one to the frame, or one end to the K-Member?
The Ed Quay kit has a bracket that welds onto the frame and another that welds onto the center link. His kit comes with pic instructions.
Doug Blackley 1697 STK |
