Old 04-13-2008, 01:43 PM   #1
CPOlesen
Default Power to Manual steering swap
I installed a 454 block in a 67 camaro. I also changed the frame stands to big block and I have Dart aluminum heads and hooker super comp 2" headers.The problem is the headers hit the Stock power steering box,which measures 5" at its widest point. I want to install a manual box because I heard it is narrower, but i don't know for sure.What is the best set up for this application..It doesn't have to be factory I just want something tried and true. Thanks for any help..
CPOlesen is offline   Reply With Quote
Old 04-13-2008, 03:07 PM   #2
NovaMan
NovaMan's Avatar
Default Re: Power to Manual steering swap
My '70 Nova had power steering when I bought it, and one of the header tubes was dented for clearance (it had a small block). I switched to a 5679142 manual steering box, and I could see there was more clearance. In fact, the header tube probably wouldn't even have needed denting, especially with poly or solid motor mounts.
I don't have an engine in it right now, so I went out and measured 4.75" from the frame where the top bolt goes in to the point where it sticks into the engine bay the most, which is the cover. I could get 1/8" more clearance just by grinding excess material off the side of the cover.
~Pete
1970 Nova
NovaMan is offline   Reply With Quote
Old 04-13-2008, 05:11 PM   #3
T Hall
T Hall's Avatar
Contact this company, Steer & Gear. I bought one from them for my 70 Nova. They are great to deal with.
http://www.steerandgear.com/
Tony Hall
3545 S/ST
T Hall is offline   Reply With Quote
Old 04-14-2008, 10:28 AM   #4
CPOlesen
Thanks A whole bunch guys !!!!!!
Old 04-14-2008, 12:37 PM   #5
Greg Barsamian
Liked 410 Times in 94 Posts
Swap it with an S-10 manual steering box.They're an easy find at parts yards.
The early S-10 Aluminum master cylinders make a great alternative to the heavy cast iron cylinders too!
Old 04-16-2008, 10:51 AM   #6
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
Flaming River makes a steering box that might have the clearence you need. Early vega box might work as well. Rack is ok, but there is hundreds of big block Camaros (stock/superstock) out there with no trouble and no racks because its not allowed by the rules. I know the factory BB frame mounts are suppose to shift the motor approx. 2 inches to the pass. side. Maybe you have the wrong frame stands?
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 04-21-2008, 02:37 PM   #7
CPOlesen
I suppose I could have the wrong stands but the headears only have 1/4 inch of clearance on the pass side now. I am going to try a manual box and see what happens.
