Old 04-03-2008, 12:40 AM   #1
Rory McNeil
Liked 1,104 Times in 302 Posts
Default Pontiac intake question
A friend of mine is building a 1964 Pontiac 389 for a 64 GTO street car, that had been using a later 400. He bought the 389 as a core, but after spending a bunch of time on the 64 heads, he noticed that the heads appear quite different than the later style that was on the 400. Mainly the 64 heads have "dogleg" shaped coolant passages, where the 400 heads had round coolant holes with a pressed in heater hose nipple at the rear of the passenger side head. According to the Edelbrock catalog, the intake manifold for a 64 and older Pontiac is different than the 65 &newer. Does (or DID)any manufacterer make a single 4 barrel aluminum intake for the early heads? This is not going to be an "all correct, numbers matching" restoration, rather a mildish street driver, so a $3000. Tri Power setup is out of the question. Also, will any Pontiac headers fit these early heads, or is there potential concerns there as well? Any other early quirks to be aware of? Thanks.
NHRA 6390 STK
M/S 85 Mustang
Old 04-04-2008, 07:30 PM   #2
Bill Edgeworth
Default Re: Pontiac intake question
Rory,
Give Dave or Marcel at SD Performance a call they may be able to help you out.
604-823-6624.
Bill Edgeworth 6471 STK
Bill Edgeworth is offline   Reply With Quote
Old 04-04-2008, 08:11 PM   #3
SAL PIACENTINI
Are there holes in the block for tle late style starter?
SAL PIACENTINI is offline   Reply With Quote
Old 04-05-2008, 08:57 AM   #4
Floyd Staggs
Floyd Staggs's Avatar
Liked 229 Times in 99 Posts
I'll probably get flamed for this but check with Bruce
mailto:IndyWinner@dslextreme.com
He knows Pontiacs.
Floyd Staggs 787 SST
Old 04-05-2008, 10:27 AM   #5
Dave Ribeiro
Liked 56 Times in 27 Posts
Wink Re: Pontiac intake question
Rory,
You or your friend can go to PYforums.com, scroll down to street or race folders and they can answer your questions...All the Pontiac guys visit this site...I am sure they can help you out.
*Floyd, I would't send anyone there !! Somethings are better left alone.....enough said...
Rory, its a great site, you guys will love it..they cover everything you can think of.. Dave,
Dave Ribeiro 1033 STK
Old 04-05-2008, 08:14 PM   #6
Bruce Fulper
Liked 54 Times in 33 Posts
Cool Re: Pontiac intake question
You know, I decided with the unbelievable amount of unbelievable disrespect some of you children wish to throw my way that I don't need to see it. I never hear any cause there's isn't a single POS that's willing to come to my face with it - cause there's nothing to say.
Rory - use your own mind - and don't be influenced by children. I've never done one bad thing to anyone and no one can prove otherwise.
All you will read is innuendo, "I heard this" - "I heard that" Oh man - he's a bad man. Never a single piece of fact. I'm up for ANYTHING boys - got it? Me and my lawyer will make mincemeat outa this site and anyoone person for allowing this bull****.
Why today? After seeing one more dickweed of a human chime in with his own negativity - Dave, -
I decided to offer my clean slate for you ****heads to make fools of yourselves with again.
Go ahead - flame away children.
And BTW - TWO idiots that race Pontiacs can't answer this simple question for Rory?
Christ alf'in mighty....................
1961 to 1964 heads have the same intake bolt pattern - 1965 to 1979 have a different pattern. You must use the intake with the bolt pattern for the HEADS you're using. Doesn't matter what BLOCK it is.
Come by and see me sometime at www.PontiacEngines.com 909-370-0389
You cannot get better help.
Still the quickest S/S Pontiac in NHRA history - FOUR YEARS RUNNING !
Bye little kiddies.
Bruce Fulper is offline   Reply With Quote
Old 04-05-2008, 09:11 PM   #7
Floyd Staggs
Dave,
Bruce has never done anything wrong to me and he has been a friend for about 14 years. I don't race a Pontiac, I have a BBC. But anytime I have ever needed advice he has always been there trying to help. I don't know what the beef is about but he has always been straight up with me.
By the way Bruce I found out that I can't run evac tubes with the mufflers I have. Flowmasters have too much back pressure.
Old 04-06-2008, 07:26 PM   #8
kirk
Liked 5 Times in 4 Posts
years ago a friend had an old edelbrock torker, that he had welded up to work with his 64 heads. that might be an option, but not necessarily a cheap way to go. didn't look butchered either as I recall.
Kirk
kirk is offline   Reply With Quote
Old 04-07-2008, 09:26 PM   #9
Kevin McClelland
Floyd, with the Flowmaster mufflers it has nothing to do with back pressure and everything to do with placing the vacu-pan nipple in the muffler. Through many hours of testing on a flow bench and on the engine dyno with a 540 big block the most vacuum we were able to create was 1 inch of mercury! This was a day of testing of different angles cut on the end of tube, location of tube, angle of tube, and all the testing was done in a straight pipe (i.e. collector) not in a muffler.
Sorry guys, didn't mean to take up a Pontiac thread.
Kevin
P.S. Bruce, did you ever get the turn downs you were looking for? One of my tech guys said that he had spoke with you about them. Take care.
Kevin Mac
765 M/SA 7652 S/G
Kevin McClelland is offline   Reply With Quote
Old 04-07-2008, 11:07 PM   #10
Jeff Goss
Jeff Goss's Avatar
Hi Rory,
Call Dave at SD Performance. He is one of the most knowledgable Pontiac guys around. He helped me a great deal back in the 90's when I ran my 68 Lemans. Brad Potter knows a bunch also, even though he turned to the Chevrolet "darkside"-LOL.
Dave is local to us and has the smarts to properly answer your question.
Hope to see you this year!
Jeff Goss
6990 SS/MA
Jeff Goss is offline   Reply With Quote
