Old 03-30-2008, 07:44 PM   #1
Rory Christianson
Liked 9 Times in 6 Posts
Default Msd Dist/with Accel Dfi ??
Can anybody tell me if they have ran into this ?
I am running small block chev injected with a msd dist. and a Accel management system
Car starts very hard like to much timing.......I talked to Accel they said there system does not work right with the msd dist, I need a phase rotor ( or there distributor) as it is trying to start on 8 rather than cyl 1, I am thinking I can retard the timing back on start up with there dfi system, they tell me it won`t do that
Talk to MSD on the phase rotor, they tell me of a timing retarder they have for start up.......so now I am thinking that is the way to go
Just add when it starts runs good, timing on the laptop shows 32............
Any help appreciated
Thanks
Rory Christianson is offline   Reply With Quote
Old 03-30-2008, 09:12 PM   #2
Bob Shaw
Liked 323 Times in 63 Posts
Default Re: Msd Dist/with Accel Dfi ??
Rory,
Do you have the MSD mechanical advance distributor ?
Bob Shaw V/SA 515
Bob Shaw is offline   Reply With Quote
Old 03-31-2008, 09:47 AM   #3
Rory Christianson
Hi Bob
Yes it is 85551 pro billet mech adv.
So it is locked in and then nearest I can tell the dfi throws 20-32 (being 50 -64) at it until the car fires up, then it goes to 32
Thanks
Old 03-31-2008, 10:17 AM   #4
csjta
You need to take some of the timing out of the Start Up Term part of the Accel
You could most likely set it to zero and it will still start fine, you will have to try different settings and see what your motor likes
csjta is offline   Reply With Quote
Old 04-01-2008, 09:52 AM   #5
Rory Christianson
Thanks for the replys
I tried adjusting the Accel to make it work, but to no avail, and I did try it at 0, and talked to them they said no, I was kind of amazed with the price of these things and everything they can do, that it won`t retard timing on start up, but I guess it is designed for there distributor, and not MSD`s.
Hey Bob
If you don`t mind I will give you a ring
When I talked to Accel they said it would work with a adjustable phase rotor, when I talked to MSD they suggested there timing retarder for start up
Thanks
Old 04-01-2008, 10:07 AM   #6
csjta
Do you have a Sportsman or Pro key?
The Accel and Msd will work together, they work together in my small block. Just a guess, it's getting timing from one of the timing tables, usually the Start Up Term table, go over them carefully.
This is a Gen7 system?
Old 04-01-2008, 01:34 PM   #7
csjta
If this is a Gen7 system, click the Ignition tab, go to Start Up Term. Under this table you can Add Advance or Retard up to 32 degrees either way. I believe you will need a Sportsman Key to get to this table, if not a Sportsman I know a Pro Key will get you there
Old 04-01-2008, 10:50 PM   #8
Rory Christianson
Hey
Thanks again for replies
Sorry Bob didn`t get a chance to call today, and not sure what time it is there now, so I will wait until tomorrow
OK, csjta
Maybe we are getting somewhere, it is a Gen 7+
We were trying to access other tables and we could not, ....I am not famailiar with the sportsman or pro key ............Is that something I can use to access these tables ???
We figured we could change this thing if we could access what we needed to, but in talking to Accel, they were not that much help, They told me that I could only retard once it was running, not when it was trying to start
Thanks Much !!!
Old 04-02-2008, 12:53 AM   #9
csjta
Accel themselves are usually no help at all, atleast on the occasions I have spoke with them.
Accel sells "Keys" with there Gen7 systems. There are 2 keys, a Sportsman key and a Pro key. With these keys you get access to all of the functions that the Accel will perform, without the keys, you are limited to what you can change. The Pro key opens all tables, the Sportsman opens most tables, but not all. You will have to purchase a key from the dealer you bought your system from or from an any Accel dealer. The key plugs into your USB port on your PC or Laptop.
Hope this helps, ask away if you have more questions I will try to help
Old 04-02-2008, 10:24 AM   #10
Rory Christianson
Hi
Hey csjta................Thanks much for the info, I went through the old box and found I do have a sportsman key............unreal I can`t believe, these guys at Accel don`t even mention this.
I will contact one of our warehouses and see if I can get my hands on a pro key, I want to be able to do as much with thing as possible.
I sure appreciate your input on this,.......ya know..... no where in there manual did I see anything about this either, unreal
Just checking it out I might need a different cable or an adapter....I will do some searching
Thanks again
