Liked 99 Times in 21 Posts
Just doing a little bench racing and looking at the 350 Chevy 250/230 with the Rochester 2GC 1686/1375. I was checking to see if any other of the GM (Buick,Pontiac or Olds) cars ran the big 2 bbl. I didn't look at them all but it appeared only Chevy listed carb. measurements on the NHRA blueprint guide. Was the big 2bbl only used on the 350 Chevy? I would expect Billy Nees or Mark Yacavone, the gurus of the odd and obscure combos to chime in on this one. I have the highest respect for these guys because I love odd and obscure combos too.
#2 | |
Liked 684 Times in 289 Posts
I agree, Billy and Mark would know. Alan Peters too. Mike A114 P/SA |
Liked 783 Times in 195 Posts
I believe that the 1969 and 1970 Chev 350 250 were the only engines to use this size carb. I queried the database for the ClassRacerInfo website and they were the only two engines that used a Rochester carb with 1.375" venturi.
There were some Oldsmobile engines from 1969 thru 1972 that used 2-Bbl carbs with 1.313" venturi. There are no listed carb sizes for the Pontiac 2-Bbl carbs in the Tech Bulletins until 1974.
![]() Last edited by Dwight Southerland; 09-18-2015 at 07:06 PM. Reason: added info |
#4 | |
Learn something everyday. Thought the 400 used the large 2GC. Thanks Dwight. Mike A114 P/SA |
#5 | |
Liked 5,138 Times in 1,961 Posts
Yeah I noticed the early 400 Chevy and 396 used the smaller carb. From what I could find the 400 and 396 carb was around 12 or so CFM less than the 1969 and I think 1970 model 350's. Wonder how much the difference in CFM was worth?
Liked 2 Times in 2 Posts
How many of the 1.375 venturi's do you need? I think i have a couple
in the shed. Also venturi clusters and baseplates left over from the local circle track racers who now are allowed to run holley 4412's. Now is it true or false, nhra no longer is enforcing the carb. P/number but as long as it meet's dimensional configuration and " original visual design" it's good...... (notice i said original design ). So with that being said and "untouched rochesters" being harder to find. Why can't the marine carb. (that meets the above specification) be used??? Easier to find (yes, even in the darn) desert and has all the good parts already installed (ok, maybe not all, but it has the "good booster cluster" and comes very darn close on the "fuel curve" needed. Norm |
#8 | |
I was told the difference between the big and small carb is about .5 Mike A114 P/SA Last edited by Mike Jones; 09-18-2015 at 10:26 PM. |
