Old 11-18-2024, 09:39 AM   #31
JP1738
JP1738's Avatar
Liked 1,171 Times in 333 Posts
Default Re: How crazy would it be.....
Originally Posted by Sean Cour View Post
Nope, one pound breaks!
Pardon my ignorance, but what do you mean by 1 lb breaks? Does that mean instead of 14, 14.5, 15 lb/hp it would just be 14 and 15 lb/hp? I can see how that would simplify Stock and cut the number of classes in half. It'd suck for me, but would make the class even more performance oriented. Be a blast to watch, but not so fun to race.
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is offline   Reply With Quote
Old 11-21-2024, 02:54 AM   #32
doglover44
doglover44's Avatar
Liked 489 Times in 227 Posts
Originally Posted by J.R. Haddad View Post
Well Billy, you say you've taken your meds, but we have no proof of that. In fact this idea would almost suggest otherwise. I think NHRA has a class just
like what you're suggesting. I believe they call it Comp Eliminator. And if for some reason spending that kind of money doesn't scare the pants right off
of you, may I suggest you contact Greg Anderson or Richard Freeman who
will work out a budget for that fits your lifestyle.
J.R.
Can Stock or Super Stock even run in comp?
Jake Biermann
Old 11-21-2024, 11:16 AM   #33
GTS340
Liked 1,341 Times in 408 Posts
There were way more car brand battles that made fastest car in class fun. No driver weight was in play in the early days. Those battles for the new generation vehicles and the folks that relate to them are only available at E.T. races now.
Paul H
Old 11-21-2024, 12:21 PM   #34
JGrossijr
JGrossijr's Avatar
Liked 460 Times in 59 Posts
1 lb. breaks get tougher at higher HP ratings. At 200 hp a racer could easily bounce between 2 classes. At 400+ HP a racer could be stuck, and there are several combinations in the 500-650 HP range.
JGrossijr is offline   Reply With Quote
Old 11-21-2024, 12:41 PM   #35
Billy Nees
Liked 7,716 Times in 1,738 Posts
This ^^^^^^^^^^^^^^^ so the guys who want 1lb. breaks, don't forget this!
Different deal but just an FYI because I've run into it, some of the FWD stuff is 3 lb. breaks. Imagine what it's like with a 140 HP combo having to add or subtract 420 lbs..
It kinda makes a combo a 1 class car in a hurry.
Billy Nees 1188 STK, SS
Old 11-21-2024, 01:44 PM   #36
JIM MARSHALL
Liked 337 Times in 46 Posts
Billy all the rear wheel drive cars I ever raced had a natural class.
I don?t know when it became fashionable to go up a class and down a class.
If everyone was forced to run their natural class more heads up would result.
The AHFS would have a better chance to work if that is what racers want.
Forgive me if it doesn?t work for FW drive cars because I don?t have any idea how they work.
Jim Marshall 1967 STK
JIM MARSHALL is offline   Reply With Quote
Old 11-21-2024, 03:46 PM   #37
Cglrcng
Cglrcng's Avatar
Liked 333 Times in 185 Posts
Originally Posted by Bryan Worner View Post
So you didnt like the idea of lowering indexes by .02 and .03 but you like this idea?
It wasn't. 02-.03 it was .200-.300 (2 or 3 tenths, not hundredths).
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can!
Cglrcng is offline   Reply With Quote
Old 11-21-2024, 04:00 PM   #38
Cglrcng
Cglrcng's Avatar
If there is not a class for you there, they will make 1 up. But, they face but at the end of each day Comp has the same issues as far as indexes. And a cure, personal permanent and immediate personal index hits. Watch the class closely as 1,000 ft drops are common among fearful yet very competitive racers.
The expensive hobby is not for the meek and you better run it like a real business or broke even the rich will be.
Old 11-21-2024, 04:07 PM   #39
Cglrcng
Cglrcng's Avatar
No need to tell me, mine is exactly 345 lbs between DF/S and EF/S...I attempted it in March, not even close to the index. And all due to the 6hp current factoring
And extra 150lbs that tacks on in both classes..
Billy sees all the pros and cons.. They call it reality and it sucks.
Old 11-21-2024, 04:44 PM   #40
Cglrcng
Cglrcng's Avatar
Jim, it works the same way as the upper classes (with a big hitch thrown in over time that screwed the pooch), back in 1994 I started racing this same FWD car in GF/SA (same Index, at 110hp). Ran I till 97 (never competitive). They lowered it in Feb 96 to 99hp...where it belonged originally. By that time I had spent a bunch chasing the impossible.
Then over time the combined FWD classes and got rid of GF-and FF recently. EF now bottom class at same 17.45 sea level index. (But added 6hp).
Imagine you run a G/SA car and one day you wake up and you are magically put into E/SA, and then they also tack on 6.5 percent more HP onto your combo.
You would run up a class also at least until you could make both the weight and the E.T. index to get it down to natural DF/S class (the car was never that light the day it drove off the assembly line), It took a ton of work to shave off 345lbs. And do it by the book. It happened, but reality bites because it
wasn't a full second faster...yet. Putting the weight back on was a necessary evil.
Parts removed went right back on in a day. 2/10ths above index was 2/10s below index at same high elevation track and down 1 class in EF/S I sit. Flogging away spending time and effort to get it to run at elevation what it is proven capable of running at sea level. We do what we must,, heads up or shoe polish driving against much faster dance partners at the stripe. And I prefer both.
But the faster the partner in the other lane is the most fun of all.
