Old 11-14-2024, 03:25 PM   #1
J.R. Haddad
Liked 1,467 Times in 307 Posts
Default Re: How crazy would it be.....
Well Billy, you say you've taken your meds, but we have no proof of that. In fact this idea would almost suggest otherwise. I think NHRA has a class just
like what you're suggesting. I believe they call it Comp Eliminator. And if for some reason spending that kind of money doesn't scare the pants right off
of you, may I suggest you contact Greg Anderson or Richard Freeman who
will work out a budget for that fits your lifestyle.
J.R.
J.R. Haddad is offline   Reply With Quote
Old 11-14-2024, 04:14 PM   #2
Billy Nees
Liked 7,731 Times in 1,739 Posts
J.R.
J.R., think about the repercussions of that and lowering the indexes and doing away with the AHFS (which is what some Racers want). we would wind up in exactly the same place!
Billy Nees 1188 STK, SS
Old 11-14-2024, 04:20 PM   #3
Billy Nees
Originally Posted by Sean Cour View Post
Let's go back to national records being the indexes. Separate the men (women) from the boys (girls)!
I have my rain coat on now, let the crying begin!
and it ain't just me!
Old 11-21-2024, 02:54 AM   #4
doglover44
doglover44's Avatar
Liked 489 Times in 227 Posts
J.R.
Can Stock or Super Stock even run in comp?
Jake Biermann
Old 11-21-2024, 11:16 AM   #5
GTS340
Liked 1,342 Times in 409 Posts
There were way more car brand battles that made fastest car in class fun. No driver weight was in play in the early days. Those battles for the new generation vehicles and the folks that relate to them are only available at E.T. races now.
Paul H
Old 11-21-2024, 12:21 PM   #6
JGrossijr
JGrossijr's Avatar
Liked 460 Times in 59 Posts
1 lb. breaks get tougher at higher HP ratings. At 200 hp a racer could easily bounce between 2 classes. At 400+ HP a racer could be stuck, and there are several combinations in the 500-650 HP range.
JGrossijr is offline   Reply With Quote
Old 11-21-2024, 12:41 PM   #7
Billy Nees
This ^^^^^^^^^^^^^^^ so the guys who want 1lb. breaks, don't forget this!
Different deal but just an FYI because I've run into it, some of the FWD stuff is 3 lb. breaks. Imagine what it's like with a 140 HP combo having to add or subtract 420 lbs..
It kinda makes a combo a 1 class car in a hurry.
Old 11-21-2024, 01:44 PM   #8
JIM MARSHALL
Liked 337 Times in 46 Posts
Billy all the rear wheel drive cars I ever raced had a natural class.
I don?t know when it became fashionable to go up a class and down a class.
If everyone was forced to run their natural class more heads up would result.
The AHFS would have a better chance to work if that is what racers want.
Forgive me if it doesn?t work for FW drive cars because I don?t have any idea how they work.
Jim Marshall 1967 STK
JIM MARSHALL is offline   Reply With Quote
Old 11-21-2024, 04:44 PM   #9
Cglrcng
Cglrcng's Avatar
Liked 334 Times in 185 Posts
Jim, it works the same way as the upper classes (with a big hitch thrown in over time that screwed the pooch), back in 1994 I started racing this same FWD car in GF/SA (same Index, at 110hp). Ran I till 97 (never competitive). They lowered it in Feb 96 to 99hp...where it belonged originally. By that time I had spent a bunch chasing the impossible.
Then over time the combined FWD classes and got rid of GF-and FF recently. EF now bottom class at same 17.45 sea level index. (But added 6hp).
Imagine you run a G/SA car and one day you wake up and you are magically put into E/SA, and then they also tack on 6.5 percent more HP onto your combo.
You would run up a class also at least until you could make both the weight and the E.T. index to get it down to natural DF/S class (the car was never that light the day it drove off the assembly line), It took a ton of work to shave off 345lbs. And do it by the book. It happened, but reality bites because it
wasn't a full second faster...yet. Putting the weight back on was a necessary evil.
Parts removed went right back on in a day. 2/10ths above index was 2/10s below index at same high elevation track and down 1 class in EF/S I sit. Flogging away spending time and effort to get it to run at elevation what it is proven capable of running at sea level. We do what we must,, heads up or shoe polish driving against much faster dance partners at the stripe. And I prefer both.
But the faster the partner in the other lane is the most fun of all.
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can!
Cglrcng is offline   Reply With Quote
Old 11-21-2024, 07:16 PM   #10
Billy Nees
Hi Jim! I'd be OK with that! I don't think that you'll find much support for it though. It would also send Racers scurrying back to the Classification guide to find the many combos and classes that time has forgotten.
