Old 08-21-2018, 11:03 AM   #31
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Default Re: Axle weight?
Just curious or you all saying that single axle can weigh over 200 pounds are is there something wrong with that scale.I can lift one of my axles with one hand this axle I would need a engine hoist to get it in the tubes.
7015 E/SA Sooner Storm
astikhossw is offline   Reply With Quote
Old 08-21-2018, 12:13 PM   #32
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
No, because the comparison is not between a 200 lb. axle and a 20 lb. axle. What is being said is that comparing the cost of a 14 lb. rifled-drilled, flange-scalloped axle to a "normal" 20 lb. axle is not justified for any performance advantage in most cases, if you are expecting the lightened axle to require less power to accelerate it. Physics shows that the benefit is extremely minimal.
Old 08-21-2018, 01:03 PM   #33
Tom Broome
Liked 88 Times in 43 Posts
Stated much better than me....ah, I. See, much better language skills.
Tom Broome is offline   Reply With Quote
Old 08-21-2018, 02:13 PM   #34
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
My thoughts......
The most bang for the buck is running worn out slicks.....
Just sayin'
Bob Mulry 7516 STK
A & M Motorsports
