#31 | |
Ed Wright 4156 SS/JA |
#32 |
Liked 10,891 Times in 2,255 Posts
Working on the Drag Pack that has a S 60 Dana housing. Is it neat or what, it has screw adjusters to set the back lash and carrier bearing preload . No more spreading the case and adjusting the carrier with shim packs.
What doesn't work is calling the tech line and receiving incorrect information. I did some further looking on their web sight and found the correct procedure to set preload. I'm real happy I double checked, it saved me a bad day at the races, money for parts, and a lot of work. Its a good product, I think. |
#33 |
Liked 886 Times in 238 Posts
I'm all for clean and shiny cars ,but over the Winter a lot of racers forget about one of the most important things ,other than a win light , Brakes !
Take some time to inspect the hoses. ... if they are more than five years old replace them ,they are cheap insurance. Flush out the old brake fluid and replace it with quality racing brake fluid like Wilwood's 570 Plus ,or other high quality DOT 4 fluid. Brake fluid is hygroscopic ,it absorbs moisture and over time becomes corrosive to your steel and aluminum brake components . We all want to keep the shiny side up !
#34 |
Liked 1,034 Times in 368 Posts
I always had issues with rear end seepage after a few months of racing . The bolts, even though they are self locking with Loctite always pounded out the gasket and leaked .. This gasket ends all that. It's a steel shim with reusable gasket material on both sides... and their cheap ..
Lube Locker Ford 9" Differential Gasket https://www.amazon.com/Lube-Locker-F...ds=Lube+locker
Jeff Niceswanger 3740 SS |
#35 |
Liked 133 Times in 76 Posts
Never wasted my time with a gasket on a 9". A tube of Ultra Black RTV and self locking nuts on the studs works for me. I used copper washers under the nuts.
#36 |
I tried that Eman ..Pounded that sealer right out of there. Took a while to start leaking, but eventually,it would. I ended up using a Loctite red gasket maker, which set up like stone when the 2 parts were crushed together, but it's next to impossible to get apart without a chisel ! These gaskets don't leak, or crush
#37 | |
Liked 799 Times in 236 Posts
https://www.permatex.com/products/ga...-gasket-maker/
"That'll never work....." |
#38 |
This stuff has to be the best stuff on the planet. A little out of my price range .
http://www.chemicalguys.com/
Chuck Beach 3340 STK |
#39 | |
http://adamspolishes.com
Ross Gregory 5133 Stock,Super Stock 53 Top Dragster |
#40 |
Don't work: Spools with .002 run-out on the pilot for ring gear, and .003 run-out on ring gear flange. Impossible for me to get .008 to .010 backlash and good contact area. A new one is on its way.
