Old 02-24-2017, 10:46 AM   #1
Rsmith38
Liked 28 Times in 15 Posts
Default Re: What Works and What Doesn't
I have also used the Awesome orange from dollar Stores - works well.
They also have a refill bottle (clear plastic, yellow liquid) for $1 which makes 3 to 5 refills - for a couple of bucks you can do a trailer! Stuff also cleans under hood on used cars, Spray on - let sit, Hose off!
Rsmith38 is offline   Reply With Quote
Old 02-24-2017, 01:07 PM   #2
Ed Wright
Ed Wright's Avatar
Good stuff!
Ed Wright 4156 SS/JA
Old 01-19-2018, 09:17 AM   #3
Liked 10,707 Times in 2,229 Posts
Working on the Drag Pack that has a S 60 Dana housing. Is it neat or what, it has screw adjusters to set the back lash and carrier bearing preload . No more spreading the case and adjusting the carrier with shim packs.
What doesn't work is calling the tech line and receiving incorrect information. I did some further looking on their web sight and found the correct procedure to set preload. I'm real happy I double checked, it saved me a bad day at the races, money for parts, and a lot of work.
Its a good product, I think.
Old 01-19-2018, 10:51 AM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 881 Times in 236 Posts
I'm all for clean and shiny cars ,but over the Winter a lot of racers forget about one of the most important things ,other than a win light , Brakes !
Take some time to inspect the hoses. ... if they are more than five years old replace them ,they are cheap insurance.
Flush out the old brake fluid and replace it with quality racing brake fluid like Wilwood's 570 Plus ,or other high quality DOT 4 fluid.
Brake fluid is hygroscopic ,it absorbs moisture and over time becomes corrosive to your steel and aluminum brake components .
We all want to keep the shiny side up !
Old 01-19-2018, 01:37 PM   #5
Jeff Niceswanger
Liked 1,031 Times in 368 Posts
I always had issues with rear end seepage after a few months of racing . The bolts, even though they are self locking with Loctite always pounded out the gasket and leaked .. This gasket ends all that. It's a steel shim with reusable gasket material on both sides... and their cheap ..
Lube Locker Ford 9" Differential Gasket
https://www.amazon.com/Lube-Locker-F...ds=Lube+locker
Jeff Niceswanger 3740 SS
Jeff Niceswanger is online now   Reply With Quote
Old 01-19-2018, 04:59 PM   #6
Eman
Liked 133 Times in 76 Posts
Never wasted my time with a gasket on a 9". A tube of Ultra Black RTV and self locking nuts on the studs works for me. I used copper washers under the nuts.
Old 01-19-2018, 05:37 PM   #7
Jeff Niceswanger
I tried that Eman ..Pounded that sealer right out of there. Took a while to start leaking, but eventually,it would. I ended up using a Loctite red gasket maker, which set up like stone when the 2 parts were crushed together, but it's next to impossible to get apart without a chisel ! These gaskets don't leak, or crush
Old 01-22-2018, 03:42 PM   #8
Alan Nyhus
Liked 799 Times in 236 Posts
This stuff really works on differentials. -Al
https://www.permatex.com/products/ga...-gasket-maker/
"That'll never work....."
