#311 |
Liked 346 Times in 126 Posts
#312 |
Liked 7,788 Times in 1,744 Posts
Again David, I'm missing your point.
#313 |
#314 |
Liked 174 Times in 39 Posts
I just looked at Nitro Joe's stats, 62/65 competitors in D/SA have an aftermarket block listed available for their combo in the NHRA Accepted Products list (no Olds 455 or Buick 455 available, as far as I know). Yes, it is unfortunate there are not better blocks available for some combinations, but that doesn't make it ok to accept an intake manifold that's was originally listed by Mopar as "the result of an extensive dynamometer and track development program" and "for your super stocker, formula car, or bracket racer."
3207 D/SA, C/ED |
#315 | |
#316 | |
If you're really concerned about an aftermarket block, make one or get one made, submit it to NHRA. You can do that if you really wanted to. I cannot make a manifold or get one made and have NHRA accept it.
3207 D/SA, C/ED |
#317 | |
Liked 1,597 Times in 583 Posts
Why are you complaining about the blocks when the subject is about intakes and cylinder heads? The majority of the racers are going fast with the OEM block both filled and unfilled. It boils down to the quality of the machine work and the final finish of the cylinder walls. |
#318 | |
And you want to limit it to that one subject. |
#319 |
Guest
Posts: n/a
David, what side of the crusade are you on? What would you like to contribute to the conversation? Do you feel that the lack of an aftermarket block for the 273-360 is reason enough for the allowance of non OEM Cylinder Heads and Intake? Am I understanding you correctly? Just clarifying
#320 | |
I am, and i see people like you and Billy doing a lot of tap dancing. How much extra hp does aftermarkets give? |
