Old 08-17-2019, 10:27 AM   #21
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
Default Re: 12V racing battery recommendations
Originally Posted by cmracing View Post
So....... Why mess with these little batteries you have to worry about charging when there are massive batteries out there that will never give you an issue?
Because in Stock, we have to keep the battery in the stock location...a group 31 on the nose of the car wouldn't be too smart.
Paul Merolla is offline   Reply With Quote
Old 08-17-2019, 03:41 PM   #22
cmracing
Liked 62 Times in 29 Posts
I understand that. I have wired Stockers and kept a small battery up front to meet the rule, and put a real battery in the back that I never had to worry about. You're right, I can't imagine a Group 31 under the hood of anything but a truck!
cmracing is offline   Reply With Quote
Old 08-17-2019, 05:08 PM   #23
GTX JOHN
Liked 2,486 Times in 697 Posts
Stock the batteries MUST be exactly the same size. NOT just same brand and similar model. I got bounced for less than 1 Inch difference in length and same width in the same brand and model. This was in St. Louis
at Divisional last year in my Demon.
John Irving
741 Stock
741 Super Stock
Old 08-17-2019, 07:36 PM   #24
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Was the smaller one in the front of the car or the back?
Originally Posted by Dragsinger View Post
However, I am softening with that stance and now think a conventional, lead-acid, or AGM 12 volt deep cycle is an overall excellent choice.
I haven't seen the deep cycle batteries last much more than 1 year. Maybe I get the wrong ones.
Dave Noll, EF/S ,?/SA 6526
Old 08-17-2019, 07:47 PM   #25
Dave Noll
Dave Noll's Avatar
Old 08-17-2019, 07:55 PM   #26
cmracing
Amazing! With all the other stuff going-on in Stock Eliminator they are worried about a battery.......... Guess it is easy to measure and check, unlike a lot of other "stuff"...........
Old 08-18-2019, 10:20 AM   #27
Mike Pearson
Mike Pearson's Avatar
Liked 1,930 Times in 580 Posts
That is splitting hairs. Seems a bit picky on that. I could see if it was a big difference. Looks like they were hunting something to bounce you which is surprising as many racers as you have helped over the years.
Mike Pearson 2485 SS
Old 08-18-2019, 12:32 PM   #28
Jim Hawkins
Liked 115 Times in 35 Posts
I work on electric forklifts and other small electric powered equipment and deal with deep cycle batteries daily. In a race car if you can handle the weight run a AGM 12 volt deep cycle and forget about them for 5 years or more. I have had good luck with deka brand group 24 AGM batteries. Weigh 45# each. I had a pair of them in the car for over 5 years and then moved them to the trailer and they are still powering the winch, lights etc. Plus you can leave them for months and still hold a decent charge.
Years ago had good luck with optima brand but at some time there manufacturing was moved out of the country. After that they did not last as long, not sure where they are made now or if that problem has been corrected.
Jim Hawkins is offline   Reply With Quote
Old 08-18-2019, 01:27 PM   #29
jmcarter
jmcarter's Avatar
Liked 3,181 Times in 972 Posts
.... Looks like they were hunting something to bounce you which is surprising as many racers as you have helped over the years.
Well, there is that tree in Pomona...right John?
Battery size is one of those areas that racers seem to receive some latitude on....but I’m all for letting sleeping dogs lie.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 08-18-2019, 04:01 PM   #30
GTX JOHN
St Louis was one of very last divisional races of the year....We had to go back to fix some damages to our average (Thanks to other folk's performance). I had not been back East racing for many many years.....I got the impression from the extended time spent going over my old car (Raced since early 90's) that I was not getting thru Tech unblemished. It was easy enough to go to Walmart and buy two batteries!
Perhaps the Tech guy was a tree hugger and mad at me for the tree destruction like Jim said ( Only God can make a Tree but any Fool can knock the darn thing down ).
John Irving
741 Stock
741 Super Stock
