Old 04-17-2013, 01:33 PM   #21
FED 387
Liked 336 Times in 183 Posts
Default Re: Fuel Pump Recommendation
Bricki--also forgot to mention since you are using a bypass/return line system the relationship of the placement between the pick up line and the bypass line is critical also to prevent aeration or foaming of the fuel--FED387
Old 06-02-2013, 07:28 AM   #22
Pony Pilot
Originally Posted by bricki View Post
Howdy classracers HELP
I have a A 1000 pump feeding 750 hp located in the trunk doorcar 1.21 sixty foot - 10 to regulator on firewall - 8 return to tank in trunk.
Fuel pressure is set at 6.5 pounds, from half track to 1320 needle on guage jumps between 6.5 and 5 pounds does anyone have an idea whats going on what are your thoughts guys.
Sounds like bad regulator to me. I have to put a plug in for Aeromotive. I bought a used A1000 pump, filter and regulator in 2004 that has worked flawlessly to this day!
Pony Pilot is offline   Reply With Quote
Old 06-04-2013, 12:45 PM   #23
rob7181
Just replaced a BG500 with a MagnaFuel 500, almost identical brackets and size. only had to drill one hole.
rob7181 is offline   Reply With Quote
