#11 |
Liked 1,900 Times in 570 Posts
I ran cast cranks in a couple of my super stock small block chevy engines. Never had a problem with them. I have broke 2 aftermarket steel cranks. Both of those broke because other parts broke first.
Mike Pearson 2485 SS |
#12 |
Liked 166 Times in 46 Posts
I have seen them both break, mostly due to detonation.
#13 |
Liked 161 Times in 52 Posts
i ran a 390 cast crank for years .. quickest we ever ran with it was 9.70s?
definetly not using cast cranks these days? it was a ticking time bomb waiting to happen ?
Stephen Johnson #2162 Horace Johnson #2167 SS/D 427 Ford Fairlane NHRA-IHRA |
#14 |
Liked 16 Times in 11 Posts
A 50oz external cast crank or something that?s been converted to internal balance?
#15 |
Liked 732 Times in 383 Posts
#16 |
Liked 2,425 Times in 687 Posts
I know several people who have used cast cranks in their 318/340
Superstock engines that run 8000+ I gave them quite a few for free as I do not run them in ours cars. Most of them have got away from using them anymore.
#17 |
Liked 4 Times in 3 Posts
It's a 290 AMC, so no aftermarket parts, and pretty much nothing to directly compare. But with a light piston and fairly short stroke I've decided not to worry about it, and mag the crank after a number of passes. These are easy to internally balance.
I think the effectiveness of the damper is one of the biggest factors in crank life, but that's another thing where there is no comparable data. |
#18 |
the last one i used had 75 runs on it? it was maged good at that time , decided to go 427 shafts ?
