Old 12-16-2023, 06:43 PM   #11
Coleydog
Liked 53 Times in 38 Posts
Default Re: Looking for info on this trans. Dynamic
Originally Posted by chopperloco View Post
Bolted
Now THAT would be great to bolt a big block mopar bell (ultra bell) on the little 904 trans, no more high dollar 904 guts in the 727 case. Hemi guys will love this.
Old 01-03-2024, 07:09 PM   #12
Coleydog
Where can I get one of these?
Old 01-06-2024, 09:38 AM   #13
chopperloco
chopperloco's Avatar
Liked 83 Times in 24 Posts
its available...
chopperloco is offline   Reply With Quote
Old 01-16-2024, 02:21 PM   #14
chopperloco
Originally Posted by Steve Grady View Post
Is the bellhousing a cast part of the case, or does it bolt on? Hard to tell from your pictures.
My mistake,not bolted -all one piece
Old 12-28-2024, 01:23 AM   #15
Adger Smith
Liked 880 Times in 311 Posts
"Now THAT would be great to bolt a big block mopar bell (ultra bell) on the little 904 trans, no more high dollar 904 guts in the 727 case. Hemi guys will love this".
12-13-2023 12:43 PM
Coleydog
I wonder if you have ever seen the 904 planataries Dave Smith produces? Nothing like the stock 904 or 727. Ultra small and lite weight.
Stock parts do not even come close..
Adger Smith (Former SS)
Old 01-03-2025, 09:00 PM   #16
Philip Baise
Please enlighten me. Where are the pictures of this trans?
Philip Baise is offline   Reply With Quote
Old 02-21-2025, 02:53 AM   #17
Cstockbird
Liked 2 Times in 2 Posts
I?d just like to say a little something about dynamic trans in CT. They built my transmission in my 468 Pontiac turbo car in 2004 my car makes a ton of torque I have pounded on this thing on the street and at the track running multiple classes round Robbin as often as I could, 100 plus passes a year and it?s still
Going strong
I actually had. Gauge reading 100 degrees higher than the measured temp at converter ( never could figure out why still does it) so I had them
Pull it apart to check it. It was like new inside. The fluid was bright red the bushings had no burn marks or wear indications
Threw it all back together as it was and continued its regular beatings. Still going strong. Figure that?s, 21 years on the same
Transmission. TH400
Only reason. I even posted was because no one seemed to really know the company. I plain wore out / destroyed a lot of transmissions before finding dynamic. Haven?t destroyed one since. (Knocking on wood). Gotta give props where it?s due though. They’ve done right by me. GMonde commented in this thread he can vouch for, it I’m not easy on this trans at all
Cstockbird is offline   Reply With Quote
Old 02-24-2025, 02:12 PM   #18
PDavidson
Liked 22 Times in 9 Posts
PM sent
PDavidson is offline   Reply With Quote
Old 02-28-2025, 12:45 PM   #19
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
I had those guys do there 9 roller bearings and drum modifications to my C-4 but I haven?t ran it yet but when I got the parts back from them I didn?t get the same drum back for some strange reason my 26/26 input shaft (aftermarkets)would no longer fit into the drum but a 24/26 input shaft would fit.So now they want me to send the drum and input shaft back to them (at my expense) both ways.So now when I get the drum and my 26/26 input shaft back they had replaced the drum with my correct drum with the 26 spline but for some reason now one end of the input shaft fits the drum but the other end doesn?t fit the 26 spline in the converter and the input shaft looks totally different (stock input) but I sent them a aftermarket input shaft.So having another conversation about it did nothing to fix the problem I just gave up on it as a lesson learned.
7015 E/SA Sooner Storm
astikhossw is offline   Reply With Quote
