Old 01-30-2021, 01:00 PM   #1
curtis reed
Liked 125 Times in 59 Posts
Default Re: Canton accusump vs. Moroso accumulator
Originally Posted by Keith 944 View Post
So if your oil pressure drops below 25 pounds the switch releases the oil in the accumulator and hopefully back to your bearings
I have a Canton and love it
Sorry I should have been more specific. I run the electric valve and let the system dictate when it needs oil not at a pre-set pressure. Why a pre-set pressure is what I meant, over letting it just free flow as needed?
curtis reed is offline   Reply With Quote
Old 02-01-2021, 12:58 PM   #2
Dano
Dano's Avatar
Liked 52 Times in 32 Posts
Without a Pressure valve, how does your system know when it needs oil?
SC 707Y
Dano is offline   Reply With Quote
Old 02-02-2021, 07:23 AM   #3
Darcy Clarke
Liked 529 Times in 36 Posts
I have used a canton 2 quart with a autimatic pressure switch that activated if the pressure gets below 60lbs. It not only saves the engine in the event of the loss of oil pressure but when you go to start the car you have 60lbs oil pressure pre lubing the engine. I would never have a race car without one.
Darcy Clarke
A/SA SS/EA
Darcy Clarke is offline   Reply With Quote
Old 01-29-2021, 10:12 AM   #4
t.tosto
Liked 62 Times in 23 Posts
mishsc, ck. your PM
t.tosto is offline   Reply With Quote
