Old 01-27-2021, 10:12 PM   #1
mishsc
Default Canton accusump vs. Moroso accumulator
Can anybody tell me if one is better than the other? Building a new car for Super Stock GT with a big block Chevy. Trying to decide which one to use. Moroso is a little more expensive but if it works better then it's worth it.
Thanks in advance.
Shane
mishsc is offline   Reply With Quote
Old 01-28-2021, 09:50 AM   #2
Rsmith38
Liked 28 Times in 15 Posts
Default Re: Canton accusump vs. Moroso accumulator
Installed the Moroso 2 years ago. Set at 25 lbs and sitting over Winter 5 months it still showed 20 lbs!! Quality!!! Have not used Canton - may be the same - can't be better. Just my experience.
Bob 1051 Stk
Rsmith38 is offline   Reply With Quote
Old 01-28-2021, 10:17 AM   #3
Nmbr1GMfan
I have no actual use comparison but I just purchased a 1.5qt Moroso heavy duty version (just the end caps are different) and it looks very well constructed.
Todd Greene
Old 01-28-2021, 01:12 PM   #4
curtis reed
Liked 125 Times in 59 Posts
Thanks in advance.
Shane
Have had both including the newer heavy duty version Moroso. If you didn't look at which one is installed in the car you would never know. The two you mentioned one is an aluminum tube with end caps held in by large snap rings with o-rings around them and the other has threaded caps screwed into the tube. They both have a piston inside with o-rings on it that slides end to end. Simple pieces really. The heavy duty Moroso version has threaded end caps instead otherwise the same.
Curtis
curtis reed is offline   Reply With Quote
Old 01-28-2021, 08:09 PM   #5
mishsc
Thanks for your input guys.
Old 01-29-2021, 08:25 AM   #6
Dano
Dano's Avatar
Liked 52 Times in 32 Posts
Thanks in advance.
Shane
Installed the Moroso on a SC Dragster with a 25lb switch, (which cost as much as the accumulator!), and 10lb of air. Sump held 2 qts of oil.
If/when the oil pressure decreased in shut-down, valve opens, no more issues and piece of mind.
SC 707Y
Dano is offline   Reply With Quote
Old 01-29-2021, 09:43 AM   #7
Frank Castros
Back in the 1970s Mike Canton worked for and developed oil control products for Dick Moroso.
Old 01-29-2021, 10:12 AM   #8
t.tosto
Liked 62 Times in 23 Posts
mishsc, ck. your PM
t.tosto is offline   Reply With Quote
Old 01-29-2021, 12:50 PM   #9
curtis reed
Why the 25lb switch?
Old 01-29-2021, 06:31 PM   #10
Keith 944
Keith 944's Avatar
So if your oil pressure drops below 25 pounds the switch releases the oil in the accumulator and hopefully back to your bearings
I have a Canton and love it
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
