#11 |
Liked 333 Times in 180 Posts
9 inch only on COPO -Cobra Jet and Drag pac is the way I understand it--I think NHRA had a post on what vehicles can use a 9 inch-FED 387
#12 |
Liked 308 Times in 103 Posts
modern parts in 12 bolt will be great in there....
pro gear absolutely a must with ANY stick even a W car..... and correctly setup if it isn't you won't get a season out of it... Randall was going through a set of gears a season on his truck... I set them up and he has 6 years on them now... knock on wood…. I have never hurt a gear or anything in my K/S car... gear has at least 300 runs.... spool, steel caps, 35 spline axle, chrome moly tubes,5/8 wheel studs all Mark Williams parts, I installed the tubes and caps and built the rest... |
#13 |
Liked 2,354 Times in 554 Posts
#14 |
Liked 986 Times in 198 Posts
Saw a 69 Camaro Stocker a few years ago with a 57-64 Pontiac r end in it at a Div. 3 Points race after any GM rearends were oked. They must have changed the ruling. Ford rearends are ok in certain years though????
#16 |
Liked 7,994 Times in 1,525 Posts
#17 |
Liked 172 Times in 81 Posts
#18 | |
The Pontiac/ Olds setup was common in the M/P and Gas classes. If the rulebook still says "of the same manufacturer" , NHRA always took that to mean Chevy, one , Pontiac ,two , and different. Now, if it says something about "corporate" , then you boys may have an argument. But then again, it seems they have already spoken on this, many years ago.
#19 |
Liked 8 Times in 3 Posts
Email from Tech Director 1/29/2020:
You are not allowed to use any rear end housing under your car other than a Chevrolet housing. It can be a 10 bolt, 12 bolt etc., but must be a Chevy housing. |
#20 |
