Old 04-27-2020, 02:05 PM   #11
FED 387
Liked 333 Times in 180 Posts
Default Re: stock class rear axle?
9 inch only on COPO -Cobra Jet and Drag pac is the way I understand it--I think NHRA had a post on what vehicles can use a 9 inch-FED 387
Old 04-27-2020, 02:29 PM   #12
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
modern parts in 12 bolt will be great in there....
pro gear absolutely a must with ANY stick even a W car..... and correctly setup if it isn't you won't get a season out of it... Randall was going through a set of gears a season on his truck... I set them up and he has 6 years on them now...
knock on wood…. I have never hurt a gear or anything in my K/S car... gear has at least 300 runs.... spool, steel caps, 35 spline axle, chrome moly tubes,5/8 wheel studs all Mark Williams parts, I installed the tubes and caps and built the rest...
Old 04-27-2020, 09:30 PM   #13
GUMP
Liked 2,354 Times in 554 Posts
A 9 inch is legal in any 2008 and newer car.
Old 04-28-2020, 01:32 PM   #14
Lyn Smith
Liked 986 Times in 198 Posts
Saw a 69 Camaro Stocker a few years ago with a 57-64 Pontiac r end in it at a Div. 3 Points race after any GM rearends were oked. They must have changed the ruling. Ford rearends are ok in certain years though????
Old 04-28-2020, 03:23 PM   #15
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
Last I knew Olds was still General Motors.
72 cutlass
Daran Summerton is offline   Reply With Quote
Old 04-28-2020, 07:26 PM   #16
MR DERBY CITY
Liked 7,992 Times in 1,525 Posts
That’s what I was thinking. ....Are you positively sure of that YAK ?
Old 04-28-2020, 08:06 PM   #17
jmantle
Liked 172 Times in 81 Posts
Doesn't make sense considering I was told I could run an 8 3/4 Mopar or a Dana 60 in an AMC (which I thought was a stretch).
Jim Mantle V/SA 6632
jmantle is offline   Reply With Quote
Old 04-28-2020, 09:37 PM   #18
What I am sure of is lots of Jr. Stockers would have loved to use a P/O rear, but instead, they went through untold grief with Chevy "P" cases and all that junk.
The Pontiac/ Olds setup was common in the M/P and Gas classes.
If the rulebook still says "of the same manufacturer" , NHRA always took that to mean Chevy, one , Pontiac ,two , and different.
Now, if it says something about "corporate" , then you boys may have an argument.
But then again, it seems they have already spoken on this, many years ago.
Old 04-29-2020, 06:30 AM   #19
XSTOCKER
XSTOCKER's Avatar
Liked 8 Times in 3 Posts
Email from Tech Director 1/29/2020:
You are not allowed to use any rear end housing under your car other than a Chevrolet housing. It can be a 10 bolt, 12 bolt etc., but must be a Chevy housing.
XSTOCKER is offline   Reply With Quote
Old 04-29-2020, 10:12 AM   #20
MR DERBY CITY
There you go, Thank You for the clarification Mr X.......
