#11 |
Liked 66 Times in 12 Posts
I had the exact same problem become present on my 305, Q Jet Camaro, it was a faulty pressure regulator at the carburetor.
#12 |
Liked 132 Times in 27 Posts
A friend had this same problem this year and found it to be a very restricted fitting from tank to pump. This was after he changed pump and regulator. It was a 90 degree fitting.
#13 |
Is this a stock fuel tank? Not a fuel Cel?
To eliminate a weak (low volume) pump, I would add 5 gallons of fuel. If that stops the pressure drop, it will usually indicate the pump pick up being uncovered due to placement in the tank.
Ed Wright 4156 SS/JA |
#14 |
Liked 706 Times in 283 Posts
It is a fuel cell with about 10 gallons in it mostly to make weight. Has rear sump and exit with pump directly behind it. Im pretty sure I 45 degree or straight fitted everything. I did install a -8 inline fuel filter when I built car 35 passes ago.
#15 |
Liked 5,129 Times in 1,956 Posts
It's the G force causing the problem.
#16 |
How quick does it ET? And 60’?
Ed Wright 4156 SS/JA Last edited by Ed Wright; 01-21-2020 at 07:13 PM. |
#17 |
Liked 1,943 Times in 584 Posts
What side of the pump is the filter. I have never ran a filter in my fuel system
Mike Pearson 2485 SS |
#18 |
Liked 311 Times in 175 Posts
If you are using a fuel filter, check the Microns.
#19 |
#20 |
