Liked 10,747 Times in 2,235 Posts
I thought the rule book said the wire had to be unbroken from hyd. switch to the twostep. I could be wrong.
Liked 431 Times in 224 Posts
Then put the on/off switch in the wire that supplies power to the hyd. switch.
S/ST 51 S/C 53 |
Liked 2,486 Times in 697 Posts
Our switches are set pretty high and not very much chance
that we will hit the two step when braking unless we go totally crazy on the brakes.
Liked 223 Times in 73 Posts
That's what I did too, I don't think I've come close to activating at the top end yet. But I do have a switch already installed, and putting it inline with power to the pressure switch is a good idea. I might try that some time. I put that switch in before I encountered the "unbroken wire" rule and never hooked it up.
Liked 627 Times in 156 Posts
That's the method I've used, I believe it complies and has worked flawlessly since I installed it about a year and half ago...
Pete Lanciers PAL Automotive Racing Stock 7801 |
Liked 150 Times in 41 Posts
Folk Switch.
