Old 07-24-2018, 09:56 AM   #11
Demon340
Liked 108 Times in 29 Posts
Default Re: Mopar tq rebuild
Originally Posted by GallopinGhost View Post
What exactly are you suggesting ? 1 builder do the same model carb 3 different ways, or use 3 different builders ?
I'm saying is find you a good builder, (Two were mentioned in this conversation) and spend the dollars. They will set you up with the right combo for YOUR car and also will give you good advice on jetting/tuning that you need while at the track.
Demon340 is offline   Reply With Quote
Old 07-24-2018, 10:38 AM   #12
cyclonebfx
Liked 5 Times in 2 Posts
That makes sense. It would be cool to see dyno testing using different center bodies(thinking holleys here) and the same mods. Probably classified info though
Keep in mind that at least on our small blocks you have two different series of Thermoquads you can legally run, and for instance the 72 and up Thermoquads as mentioned can be ran with metering rods or with the Holley jet conversion so ya I know there has been a lot of testing done. These are really pretty cool carburetors to work with and just reiterating what was mentioned before you just have to start trying things out cause the tuning (car included) and elevation will make a difference on how they behave.
5705 F/S
5706 D/SA
cyclonebfx is offline   Reply With Quote
Old 07-24-2018, 02:00 PM   #13
Liked 10,650 Times in 2,209 Posts
I hear the big carb is faster, any truth to that?
Old 07-24-2018, 03:59 PM   #14
cyclonebfx
Speaking for myself only, I have heard there is some truth to that but have never tried it personally. We have no interest in it if it isn't legal with our combos. I do have a stroker motor I've thought about trying it on just to see but never have got around to it.
5705 F/S
5706 D/SA
Old 07-25-2018, 08:02 AM   #15
tstickff
tstickff's Avatar
Liked 548 Times in 136 Posts
300 plus a carb? thats pretty cheap, I think to have one built you can expect more like 800-1200 to have a good carb built.
Tim Stickles
tstickff is offline   Reply With Quote
Old 07-26-2018, 05:52 AM   #16
tpoh815
tpoh815's Avatar
Liked 28 Times in 11 Posts
Talk to Brad Van lant. Big carb is used on the 360 combo. 50 more cfm than the smaller version. Supply a good rebuildable core or see what he has and he will do the rest. As mentioned earlier buy one play around with it then try another. Price is a bit more than $300. More like $500. Good luck.
EX 5-Doorstocker
tpoh815 is offline   Reply With Quote
Old 07-30-2018, 11:34 PM   #17
GTX JOHN
Liked 2,425 Times in 687 Posts
X2 on Brad
I have some small block combos that can run either big or small carb.
I never see much difference between the performance
on our small block stockers.
John Irving
741 Stock
741 Super Stock
Old 08-13-2018, 08:53 PM   #18
Rod Greene
Liked 242 Times in 81 Posts
The 4972,4973 are by far the quickest small TQ's
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
