Old 01-15-2019, 12:36 AM   #11
Eman
Liked 133 Times in 76 Posts
Default Re: Brake problem
Did you find the problem?
Old 01-15-2019, 07:47 AM   #12
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Yes master cylinder
Old 01-15-2019, 11:38 AM   #13
Eman
So the MC wasn't sending as much pressure to the rear as the frt.? Are you running a replacement Mopar MC? I've got a Dorman Mopar MC on mine which is an 85 Camaro. Only thing about it I didn't like was the shallow bore where the rod goes into the piston. I modified my pedal quadrant to support the rod so it could never fall out. I've got a plate on the firewall but I do notice the firewall flexes a little too.
Old 01-15-2019, 01:14 PM   #14
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Originally Posted by Glenn Briglio View Post
Yes master cylinder
Did you happen to teardown the old master cylinder to figure out where the leak occurred ?
ss3011 is online now   Reply With Quote
