Old 10-14-2023, 01:34 PM   #101
bubski
Liked 165 Times in 60 Posts
Default Re: Flat tappet lifter failure
Bubski can't believe this crazy train has derailed into a no "heads up" no performance based category !! Now back to lifters !! Imagine adding to the vegetable soup of stock classes with additional classes for cars with or without roller lifters ?? Bubski would like to present an example of this fine mess being pushed in Stock !! How about rU/SA the "r" being for the roller lifter designation !! Sooo!! how about f-U/SA ?? pretty self explanatory I believe !! The f-U/SA class will be 6 rounds at any class racer if they do this just because !! Cheers !!
bubski is offline   Reply With Quote
Old 10-14-2023, 03:54 PM   #102
Billy Nees
Liked 7,783 Times in 1,743 Posts
Sorry Bubski but I can't get behind *-*/SA, it's too close to something some woker would say for me.
Billy Nees 1188 STK, SS
Old 10-14-2023, 07:15 PM   #103
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
Originally Posted by Stan Weiss View Post
Terry,
Since it seems getting lifters is a problem. Is the cam still OK? If so have looked for someone who can resurface those lifters?
Stan
Nope. Cam is junk. Lifters are junk. Oil pump is junk. Pistons? questionable if they can be saved. rod and main bearings, rings. All junk.
The problem is getting lifters that will last. Coating does not work. Tool steel on certain cams won't work. Seems only thing that will work (sometimes) are 15 year old lifters that are not available anymore.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 10-14-2023, 08:15 PM   #104
e vassar
Liked 271 Times in 107 Posts
Originally Posted by Alan Roehrich View Post
Without heads up races and class eliminations, Stock and Super Stock literally have ZERO reason to exist. Period.
Go back and read my post I am all for class eliminations. This is where the folks who have done the hard work and/or spent the money will be rewarded.
So on the other side...I read a lot here that stock is a dying thing..only the old guys are still running it. How do we get younger..how do we save it? Personally I'm fine with it just the way it is. I continue to work and spend to trying to get better and faster...but..I think if you talk to 100 talented bracket racers (sorry I used the "B" word" They will tell you..OK so I'm driving good, I'm dialing good and I lose third or fourth round because I had a heads up I didn't have a prayer to win. Its just food for discussion....
Old 10-15-2023, 10:15 AM   #105
1347
1347's Avatar
Liked 1,001 Times in 276 Posts
Heads up racing in eliminations is just as, if not more important for most classracers. Its a great feeling to get your car ready for a heads up run during the eliminator, win it, then put it back in bracket mode to run next round. And for those that come out on the losing end, it gives them the drive to make their stuff faster.
Having Stock and Super Stock a heads up in class only would be a slow death to the sport to try to cater to bracket racers to be interested. They arent coming in even if it went to that.
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 10-15-2023, 10:46 AM   #106
Chevy55
Banned
Liked 179 Times in 89 Posts
Here's a good take on the lifter problem
Chevy55 is offline   Reply With Quote
Old 10-21-2023, 01:32 PM   #107
jmantle
Liked 172 Times in 81 Posts
Has anyone converted Shubeck Hyd over to solids?
Mine are converting themselves, 3 have the plungers stuck in the bottom position. Other than that, they still look like new after 12 seasons.
I would think with the new solid lifters allowed rule a better ceramic lifter could be built as they wouldn't have to allow room for the plunger, just a thought.
Jim Mantle U/V/SA 6632
jmantle is offline   Reply With Quote
Old 10-22-2023, 09:27 AM   #108
Terry Cain
Terry Cain's Avatar
Just a guess but prob very few are in market for ceramic lifters. ain't been a motor built since 85 with flat tappets in Detroit. Just a guess.
Terry Cain ???? STK
Old 10-22-2023, 11:07 AM   #109
Rory McNeil
So,..if you are set on being able to run roller lifters in a Stocker, there are almost 30 years worth of engine combinations in the NHRA Classification Guide that came from the factory WITH roller lifters, for you to choose from.
NHRA 6390 STK
M/S 85 Mustang
Old 10-24-2023, 04:12 PM   #110
Terry Cain
Terry Cain's Avatar
Gotta ask yourself WHY did OEM decide to go to rollers if flats are cheaper to make?
Terry Cain ???? STK
