Liked 1,074 Times in 294 Posts
I see that Toyo lists 3 sizes of "stickshift" application 9" slicks designed for Stock eliminator cars, has anybody ever tried them on a stick car? I`ve been running the M/T 3056ST "stick" tires on my 85 Mustang, but a slightly shorter tire would help gearing wise. Also, since Coker Tire has taken over the Phoenix brand, is anybody aware if the F14 "stick" compound is still available, and how it compares to the old Firestone tires?
Rory, you have a PM.
Cam |
Liked 4 Times in 2 Posts
Rory, Jim Devine runs them on his Duster, i just traded him a new set that i was going play with on the Challenger!, but the 4spd. was sacraficed to a auto so no need for them, he says small burn out. they work for him. im sure it depends on the H.P. of the car.
JIm, did you sell your Jerico stuff yet? Also where did you buy the Toyo slicks from? Thanks.
Rory, Les Schwab tire stores down here in season they were $190.00 a pair, i believe Gary Mckoy want's the stuff, ill check with him!, why do you or some you know. it needs to go!
Hey jim.What do you have for 4 speed stuff?Shawn
Hey, i have everything i took out of the challenger, it's big block sheild, Mcleod soft lock, & the jerico trans.308 first gear. basicly from engine to drive shaft. plus shifter.
Liked 242 Times in 81 Posts
Jim,How much for the trans?
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects. |
Rod. don't have a clue! give a call 425 941-8765
