Old 12-08-2008, 07:34 AM   #1
rick lester
Liked 4 Times in 1 Post
Question T.B.I. and manual trans question......
Hopefully someone has used a t.b.i. chevy set-up for stock and can give me some input. I plan to race a 91 s-10 with a 4.3 and manual trans. If I'm not mistaking, the throttle body for a 4.3 is the same as a 5.0, 5.7 and 7.4, just diff. injecters. With that being the case, if a factory computer is used, can it be programmed to take the desired specs it will require to run low 12's? If not, can a FAST system be used and be programmed to run a t.b.i. system. What manual trans would be a good starting point? Yes a jerico or a g-force would be better, and some might be thinking to just spend the money now and be done with it, but since this is a starter stocker I just want to get it going first then update as funds come in. I want to get this going a.s.a.p., I just joined SSSSA and I want to race so bad. Might start out as a W/S first (4 banger with stick) just to get the blood pumping again. I think as a w truck it will at least run the index, but way off the record. STOCKERS RULE!!!!!!!!!!!!!!!!!!!!! Rick.
rick lester is offline   Reply With Quote
Old 12-08-2008, 02:49 PM   #2
Rory McNeil
Liked 1,073 Times in 293 Posts
Default Re: T.B.I. and manual trans question......
I can`t help you with the FI questions, but I would likely just "bite the bullet", and buy a Jerico right from the beginning. I have a 85 5.0 Mustang, and like you I just wanted to get racing it as soon as possible, on a budget. Well, after the first year, I had several broken, wounded and patched up factory T5 transmisisons in my garage. Since then I have bought a good used Jerico, and haven`t looked back. I also have a Jerico in my 10.0 ET bracket car, (I bought that one used as well, over 10 years ago) and between the 2 cars, over 8 years of racing in the bracket Fairmont, and 4 years in the Mustang, I have not broken a single part in either trans. PLUS, I could likely sell them for what I bought them for. Probably the best investments I`ve made in race parts.
NHRA 6390 STK
M/S 85 Mustang
Old 12-08-2008, 08:52 PM   #3
Bob Shaw
Liked 295 Times in 60 Posts
Rick,
I have built and raced 3 stockers with the 4.3 and tbi. I recommend you use a Holley Commander 950 ecu to control the fuel injection. I would be glad to help you get started. The 454 throttle body is larger than the 262 and 350 throttle bodies.
Bob Shaw V/SA 515
Bob Shaw is offline   Reply With Quote
Old 12-09-2008, 06:07 AM   #4
rick lester
Thumbs up Re: T.B.I. and manual trans question......
BOB, thanks for the info, I knew that holley makes g.m.'s tbi's, and now that I think of it, that makes perfect sense. Do they sell the ecu and wiring seperate? Maybe just buy a used set up and use what I need.Email me at racerrick2881@yahoo.com. RORY, I agree with you 100% about buying the best parts for the job the first time, but with only an estimated 275 hp at the most I feel a t-10 or a m-22 would work, but that would be just a starting point. A jerico or a g-force is on the list. My biggest starting point on this project will be talking Dana into giving up her S-10. No a/c, maual steering, rubber floor mat, slow 4 cylinder with a 5 speed. I'm more than willing to buy her a full size chevy, loaded! Still no. I figure if I get her the full size truck, I can use it to go racing will she uses my cold a/c automatic fully loaded oldsmobile delta 88 will I'm out.She can even use my 68 delta 88 convertible. Women, can't live with them, can't get them to do anything you want.HELP ME! STOCKERS RULE!!!!!!!!!!!!!!!!!!!!!!!!!!!! Rick.
Old 12-09-2008, 08:46 PM   #5
Bob Shaw
Rick,
Holley will sell you the ecu, wiring and sensors as a kit to use with your stock fuel injection.
Bob Shaw V/SA 515
