Old 12-09-2008, 07:02 PM   #1
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
Default Brake lines
What size SS braided lines would be for replacing the stock rubber lines ?. I am getting some new aftermarket front brakes, and was looking for the size for both ends and an approximate length needed.
What bearing grease does everyone like ? Synthetic , I am guessing....
Thanks
2894 STK
Old 12-09-2008, 07:16 PM   #2
SSDiv6
Liked 1,538 Times in 575 Posts
Default Re: Brake lines
Thanks
There are companies like Goodridge that sells the specific brake lines, properly crimped and leak tested. For bearing grease, get the grease sold by Lamb.
Old 12-09-2008, 07:18 PM   #3
Bill Grubbs
Liked 564 Times in 66 Posts
Kenny,
We use -3 to each caliper (front or rear) and -4 for the front to rear run (each end of the hard line). Make sure teflon lined hose is used. They are relatively easy to make if you are careful and pay attention to what you do.
Bill
Bill Grubbs is offline   Reply With Quote
Old 12-10-2008, 09:28 AM   #4
Kenny Wigington
Thanks to you both ! Hi Bill, thanks for your help at Atlanta again. Say Hello to Brenda for me!
Merry Christmas all !
2894 STK
