Liked 507 Times in 116 Posts
Has anyone installed the Aerospace rear brakes on their 68-72 Nova and found with the staggered rear shocks that one of the calipers is close to the shock almost blocking the brake hose inlet?
68 Chevy11 327 F/S |
Liked 4 Times in 1 Post
I have never done aftermarket brakes on a stock rear suspension car, only 4-link type cars and dragsters, but I will throw a few things out to you........I am assuming you have called Aerospace and they said "your the first person thats ever had a problem........", not beening familar with staggered shocks, can you move everything from one side to the other and not have the same problem? If it can be done, remember the bleeder valve must be on top of the caliper. I am sure you know that but I have seen it on other so called long time racers race cars. Now if you can, some schools of theory on calipers in front or back of axle; I have personally run calipers on a dragster with both set-ups and never had a problem. The front brakes do 75 to 80% of the stopping power, so as long as the rear brakes are done correctly, there should not be a problem. IF the answer to swapping sides is no............... how close is the brake line fitting? Are you running the line in the factory location? Can the shock be spaced away from the caliper? Is it close due to an aftermarket traction device (bar just sounds way too old school)? Can a new bracket be made to move caliper down? can the bracket be modified with offset inserts in the brackets? (sim. to advance/retard bushings in timing chain sprocket) I'm sure there are more answers to this question, I am actually interested myself. STOCKERS RULE!!!!!!!!!!!!!!!!!!! Rick.
My neighbor has a 68 Camaro and has the same problem. he decided to move the calipers to the front of the axle instead of the rear. Don't think he has it completed yet, but it looks good that way.
Next time wave all of your fingers at me. |
They told me that I could run one caliper mounted on the front on one side and one on the rear. I don't think so!!!!! The shocks are mounted on the Cal Trac spring perches. After all is said and done when the fittings I ordered come in I'm hoping to at least have 1/4 inch clearance between the shock and the fitting.
Liked 279 Times in 68 Posts
I had the same problem on my car and had to run one caliper on the front and one on the back. You also have to press out the bushing where the bolt goes through on one of them and turn it around. They work great and I have had no problems with them.
Greg |
I was able to move the shock inboard so that I have 3/4 inch clearance now. It should be OK.
