Old 11-26-2008, 02:45 PM   #9
Woodro Josey
Liked 3 Times in 1 Post
Default Re: SBC stocker oil pans
Robert we machined a 2" hole in the side of it and made a plate of 1/4" Aluminum big enough to cover the hole and drilled a couple of mounting holes in it with matching holes in the pan. then Installed bolts thru from the inside and welded them to the pan, that way when using the inspection cover you don't have to worry about them backing out. As for sealing, i just used a good silicone between the pan and plate, no leaks!
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
