You have a PM.
'67 Camaro 1.25 5.77 @ 118 |
Banned
Thanks for the PM. Appreciate the input.
Liked 1,912 Times in 429 Posts
Most of the stuff in the steering linkage is often Moog or TRW. Most of what is seen in A arm bushings is Del-A-Lum or other Delrin stuff, although there are some using bearings. There's a longer upper ball joint that helps geometry a lot, it's commonly found in circle track stuff. Springs depend on the combination.
Alan Roehrich 212A G/S |
Liked 13 Times in 7 Posts
Sean Kennedy I hear you. I also wonder the same question. If someone is willing to help one person then why not all.
Gary Wisecarver sells the upper/lower control arm bearings and a quality aftermarket tie rod tube will do. I think Hotchkis and Global West sells them. Ball Joints were already mentioned above Moog will have the rest. Pitman arm Idler arm Centerlink Inner/Outer Tie Rods
N/A |
One last comment.
If ANY of you see me at the Div 3 races (NHRA/IHRA) and need help just stop by and ask. I'll help out as much as possible and I hope any info will be worth a damn to you, but no guarantees it will help ![]() 69 Camaro (Blue) running SS/BA or CA and setup to BRACKET RACE in Super Stock
N/A |
I find it easier to do front end work (springs, control arms) with the motor in.
The extra weight works to your advantage.
Bobby & Norene Zlatkin L/SA |
