my question is about using a bypass regulator. this is a new thing to me, can i set the car up with the bypass in front of the carb with a AN flare tee then run the return line back to the tank? any help would be helpful....
Liked 57 Times in 14 Posts
We use an Aeromotive regulator that is mounted up front, behind the passenger side headlight. Two outlet lines to a 'Y' that feeds one line to the carb. We have a return line that comes directly from the regulator back to the tank. The "Y" block has another outlet that we have a pressure gauge screwed into. 4 psi does the trick for us. If you're already familiar with the q-jet, you know that there is limited bowl volume. We have the pump pressure at it's maximum so we don't lose any volume during the launch. If we don't run maximum pressure, then the fuel in the line to the regulator stalls and actually runs the bowl dry. This might be different for an automatic. Hope this helps.
Mike Voth 5189 GTN - 5188 GTO Voth Racing Last edited by Mike Voth; 11-02-2008 at 06:33 PM. |
I wonder how it would be to place the regulator after the carb inlet?
You would lose no volume through the regulator, and bypass the excess back to the tank. ![]()
"Despite the high cost of living, it remains popular." Dave Cook NHRA N375 |
Dave - Do you mean running full pump volume to carb, then regulating the rest back to the tank? Q-jets are finicky. They bubble over with too much pressure.
Mike Voth 5189 GTN - 5188 GTO Voth Racing |
Liked 110 Times in 29 Posts
The regulator location and plumbing that Mr. Roth has on his car is, in my opinion, the best way to feed a side outlet Quadrajet (assuming that is what he uses). However, the best situation, again my opinion, is to use a late model, front outlet Q-Jet with the regulator mounted directly in front of it, using both outlet ports to a y-block, then to the carburetor. The 75' and later Q-Jets have more float bowl volume because of the aneriod cavity and the front outlet eliminates the severe 90 degree turn the fuel must make before the needle & seat in the side outlet carburetors. You can and should do some work on the side outlet Q-Jets to help the fuel turn the corner. This set-up is hard to do on Chevy combinations in Stock because of the thermostat housing but the carb spacers and taller manifolds in Super Stock make it doable. Hope this helps. Danny @ Q-Jet Performance
Sorry, it's Mr. Voth. My bad
If you want to see how the quickest Quadrajet equipped Super Stocker on the planet plumbs his, check out Don Kennedy's thread----Let it all hang out in Vegas GT/AA page 6. Definitely works for them! Congratulations to Frank and Phil on your Shoot-Out win! Danny
Wow. We haven't been able to run that style regulator in many years! The automatic beast is definately different than the stick shift beast.
#9 | |
Liked 293 Times in 65 Posts
Paul- One thing I've learned in the Q-Jet business is that everyone's car is different and some things are not set in stone. I still believe the system I described is ideal because the y-block set-up acts as a reservior for more available fuel to the carb., and mounting the regulator in front of the carburetor allows inertia to work for you pushing the fuel into the carb. I know that Phil is really high on the brand of fuel system they run and that may have something to do why their system works as well as it does. Maybe someone else's pump and regulator wouldn't work with this plumbing arrangement. You must understand that needle & seat size, bowl volume, line size, and fuel pressure all contribute to an effecient fuel system. Obviously, Phil and Frank have everything working together to perfection. Hope this helps. Danny
