Ok so I have posted on here several times this season and now our racing season is over, I am posting a couple links to pics of my car launching, just wanting to know how I can get the wheels up a little more to guarantee maximum weight transfer all the time mainly in the scorching heat, the car is good but not great and thats where I wanna be here are the suspension specs...
Slide a links rancho Rears Afco multi Leafs Koni Spa1's in front 214 rate moroso springs 4.56 Gear 5600 Converter Trans brake 30x9 Tire 400 Turbo Car 60's 1.48-1.49 ETS 1/8th mile 7.10's Any and all suggestions are appreciated. Here are the links. http://i50.photobucket.com/albums/f3...825/10-109.jpg http://i50.photobucket.com/albums/f3...newwheelie.jpg
Eric Bowling Last edited by ericsz; 10-28-2008 at 03:29 PM. |
Liked 128 Times in 41 Posts
Pm'd ya
Liked 26 Times in 13 Posts
Ditch the Koni's and put on a pair of Calvert front shocks. Best $100 you'll ever spend.
Can the engine deal with more top end RPMs? If so, you should put more gear in it. JMHO. Good luck.
Bill Harris ex 2172 STK ex 2272 S/S |
Engine is pretty well topped out as it is, thanks for the response.
Eric Bowling |
Eric Bowling |
Eric Bowling |
Liked 244 Times in 26 Posts
Use the Cal-Trac suspension system. It just flat works.
Liked 69 Times in 30 Posts
Cal-trac best set up for the money just ask anyone winning in stock
Your car looks fine off the line. You should rethink the idea of getting more air. Once you front wheels are of the ground you have 100% of the weight transfered to the rear tires. What you should be looking for is the least amount of power to move the car forward the quickest. Look at the shocks for control. The Konis are fine. If you need to go futher you may want to look into converting them to double adjustables. The goal of the front shocks is to control the rise and fall of the front end. The most efficient launch is when the front end rises slowly and settles down slowly while the car is still accelerating. The rate that the shocks extend and collapse is dependent on many factors: Tire size, rear gear ratio, first gear ratio, T-brake, torque converter stall, vehicle weight, horsepower, track conditions, etc.
If you were to graph the front bumper during a launch you want a nice even rise and a nice even fall throughout the first 20-60 feet. You don't want the bumper to pop up quickly then fall slowly. you also don't want the bumper to pop up quickly then fall quickly. Optimum weight transfer occurs when the front shocks are at Maximum extension. Read up on Center of Gravity, Instant Center and Percentage of Rise. Find someone who can help graph this for you and you'll be on your way to a hard launching car without the unwanted air time. |
Liked 6 Times in 4 Posts
Take weight off the front end.......
