Old 10-27-2008, 04:49 PM   #1
Jeff Lee
Jeff Lee's Avatar
Default Re: stock eliminator
Originally Posted by CamCam View Post
just to let you whati have. 12 bolt rear with either 4.88 or 5.13 gears have both. 8point chromemoly cage,caltrac bars with springs,rancho 9000 shocks rear,afco front shocks.solid body bushings the front sub frame will be rebuilt but don't know which produts to use. eng spec's jand e pistons stock crank and stock rods,factory 163 intake and aluminum heads .don't have a carb yet.but still looking.71 454 4bolt main block,bullett cam don't have lifters yet.can you still get the shubecks? gonna try to get the rocker system from holroyd. don't have rings or bearings yet,that i'll need help with,i hear talk about the coated stuff. so far this what i'm working with, any suggestions.
thanks cp
Yes, I didn't hear mention of a trunk full of CASH!
Jeff Lee 7494 D/S '70 AMX
