Liked 2 Times in 2 Posts
hi
i'm new to this fourm. i recently picked a 67camaro rs/ss. i'm going to turn it into a stocker. it's not a complete car. i've got my work cut out for me that's forsure. ialready have the engine block crank rods and some other engine parts that i've collected over the yrs. i live in phoenix az and i've met a couple of guys on this fourm at the nat's and the div's in phoenix. the combo that will be put in the camaro is the 396/375 with the aluminum heads and jerico trans. let me make this very cleari'm not trying to become top dog,just want to race and have fun.don't care about records just want a good 8-9 under car. NOW WHO SHOUILD I DEAL WITH ON THE WEST COAST PHOENIX, CALI AREA . I'M LOOKING FOR SHORT BLOCK MACHINING AND CYLINDER HEAD WORK.MOST CAM COMPANIES ARE PRETTY CLOSE ON OFF THE SHELF CAMS. But i do have a bullett cam. so any help would be greatly appreciated. so tanks in advance,any info is better than none. i was thiniking of sending my heads to juan mendoza don't have phone # or address ,anyone with that info. my personal e-mail address is wolfpack85040@yahoo.com so thanks cp |
Liked 346 Times in 126 Posts
You have an PM
Liked 509 Times in 117 Posts
As far as clutches go, spend the money right the first time at call Rob at Advanced Clutches. His contact information is on his web site.
http://www.advancedclutches.com/
68 Chevy11 327 F/S |
Kip Martin.
Kip Martin does great work and is probably more affordable than the next guy I suggest. His shop is around Deer Valley & 67th Avenue.
He currently has the SS/L record at 10.19 with a 289 Mustang and he has a close working relationship with both of his sons who work in the pro-stock engine building team of Reher-Morrison. The other guy is Bud Yancer of MACH Development (see www.machdevelopment.com) and is located on 38th Ave & Indian School. He is one of those seldom seen or mentioned reace engine builders as many of his customers will mis-lead others away from him. But he just had a #1 qualifying '68 428 CJ Mustang as well as a #1 qualifying '67 383 Barracuda recently in Stock. And he had my '70 AMX 390 as #1 in Stock. How's that for diversity? And the guy knows Chevy's. In fact I just saw a dyno last week on a 9.8:1 427 BBC that made 656 HP on 91 octane. The shop is entirely in house which includes crank grinding, cam building (not spec'ing, building), coatings, flo-bench, balancing & dyno. About the only thing they send out is the nitriding treatment. But if you only want 8-9 under he may not want to work with you. And if you want it on a budget and quick, he's not the guy either. But if you want it right (fast and durable), he's the one. Personally, I would love to see a 396/375 out of his shop. I absolutely believe you would have a one-up on all the other 396 experts. And without a doubt, Advanced clutches is the only way to go. See www.advancedclutches.com or see many comments in line at www.umtrnorth.com/forums for stick only race site. You can call me if you like, I live in Anthem, e-mail me for my number if you like.
Jeff Lee 7494 D/S '70 AMX |
#6 | |
Welcome, Send me a PM, if you'd like to hear my thoughts on your project.
just to let you whati have. 12 bolt rear with either 4.88 or 5.13 gears have both. 8point chromemoly cage,caltrac bars with springs,rancho 9000 shocks rear,afco front shocks.solid body bushings the front sub frame will be rebuilt but don't know which produts to use. eng spec's jand e pistons stock crank and stock rods,factory 163 intake and aluminum heads .don't have a carb yet.but still looking.71 454 4bolt main block,bullett cam don't have lifters yet.can you still get the shubecks? gonna try to get the rocker system from holroyd. don't have rings or bearings yet,that i'll need help with,i hear talk about the coated stuff. so far this what i'm working with, any suggestions.
thanks cp |
#8 | |
