Old 09-15-2008, 10:57 AM   #20
SSDiv6
Liked 1,583 Times in 582 Posts
Default Re: LT1 Nova
Originally Posted by Alan Roehrich View Post
The Edelbrock Olds head uses regular studs and guide plates. However, it would not be a problem at all for Edelbrock to make a run with 5/16-18 threaded rocker bosses to accept factory valvetrain. They did not alter the valve location or angle on the Edelbrock head.
You do not need to run the factory rocker bosses anymore, the rules are already changed to allow guide plates and studs.
Refer to:
Stock Cars
Section 9A
Engine: 1
Page 136 (05/08)
Camshaft/Lifters: Delete last sentences of paragraph and replace with "Larger diameter pushrods permitted. Pushrod guide plates permitted. Cylinder head may be clearenced for larger diameter pushrods."
