#11 |
I just had my ATI rebuilt. Actually it was sent in to get a different durameter (sp?) isolater ring for a higher RPM going from Stock to SS. After ten years of use it was in perfect condition. I also saw that episode of Pinks. I knew immediately it was a balancer ring. Get what you pay for!
Jeff Lee 7494 D/S '70 AMX |
#12 |
Fluiddampr
Never had a problem with the 2 I have owned |
#13 |
Liked 1,586 Times in 583 Posts
Fluidamper is heavier than most; does not work well in all applications either. There is an SAE paper on racing balancers and Fluidamper was not that good in dampening the harmonics and/or preventing crank flex.
#14 |
Liked 2 Times in 2 Posts
ATI here. Our last engine had over 227 passes on it and if I didn't know any better I would've put the bearings back in it.
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
#15 |
Liked 482 Times in 159 Posts
Fluidamper, no problems, 468 cu in, 13 to 1 compression, 4 seasons.
#16 |
Thanks to every one who gave there opinion.New ATI blancer will be here on tuesday.
Alan Warman STK 4107 |
#17 |
I run Ati and fluid dampner-No engine issues with either. But the Ati is harder to get off-Tightest balancer I have ever run even after honed some.
#18 |
ATI on our pontiac engines.No bearing issues,hundreds of passes.Although we have one pontiac 400 that sits in the corner waiting for a rebuild that has a TCI rattler on it that has about 800 passes on it,1 set of bearings at about 300 passes,and that was a waste of money because they looked almost new.
