Liked 120 Times in 48 Posts
It was a 350 in 71' used a turbo 350 with 5.13 gears.
If I remember correctly it's a G,H,I combo.
Bobby Lundholm 3516 G/SA |
Liked 330 Times in 178 Posts
71 Nova 200 HP 307 cu in available both 2 & 4 door--Comp 387
The 72 307 is only at 175 in the nova.......clarence
Liked 7,682 Times in 1,730 Posts
Unless you're "indepedently wealthy" or into self inflicted pain, I wouldn't do a big block combo right now. I am trying to get a 307 car to work and even at 175 hp the carb is just too small. The 6 cyls. are cheap and fast but too inconsistant. If I were starting from scratch and had a nice body with a 10 bolt in it I would do a 70 350 2V @ 230 hp. The specs on that combo are so screwed up to the good that I'm suprised that there is only one running (Kinash). Check it out.
Liked 66 Times in 37 Posts
Billy I told Kinasch he could gain 10 cc's with a front end swap
I told him too. The swap is done to my knowledge.
