Liked 5 Times in 2 Posts
What are the opinions of a Scat 5.7 Connecting Rod for a Super Stock application?
Thanks.
Brett Brown 7257 STK, SS, COMP |
Liked 60 Times in 12 Posts
They may be fine, but I'd buy Manley's. Its a peace of mind thing.... spend it once, ya know. My original engine builder, convinced me, and I'm glad he did.
I better go find some wood to knock on , now that I said that......
2894 STK |
Liked 358 Times in 103 Posts
You get what you pay for in most cases.
Any of them can fail. I pulled the eye out of a Manley connecting rod back in the 1990's. Manley did give me a new full set of rods but I still lost a block and a couple of pistons and cam in the deal. My 2 Cents |
yup...no matter what you buy, **** happens. I've seen them all fail...but if you check them when you get them completely/ big end / small end/ length/ Mag, you might ward off some problems...would'nt belive what I've seen in the past 35 years from all of them...
Liked 880 Times in 311 Posts
So true Bub...
Had a customer want to supply his own parts for a BB SS engine. He furnished all the parts. He did get a name rod, but they were out of parallel big end to little end about .006. Try to explain that when checking the deck height. You have to check & recheck any brand.
Adger Smith (Former SS) |
#6 | |
Liked 66 Times in 37 Posts
All aftermarket rods are made in China. I believe Howards are the only ones left in USA. Ask Manley they will tell you the same.
I have used Scat rods in my bracket engine for years, and now my Super Stock engine. Never a problem. Wesley got them approved for me. I had to donate a sample rod. That is why Scat is listed. Wesley submitted it for me at the end of last summer.
Ed Wright 4156 SS/JA |
I have had 2 460 ford motors ruined with eagle rods . they snapped in the middle of the rod.
I launched these motors at 1k rpm shifted at 5500 went thru traps at 6400. both had less than 10 passes. I found out eagle is a chineese rod.. Same as scat Never again!!! |
#10 | |
They are both from China, but the Scat stuff is machined here. The engine builders I have talked to won't use Eagle. I know several that do use Scat. One uses them in all his circle track sbc engines and says he has never had a rod or crank failure. They get a lot of run time around 8000 RPM. I'm not easy on my stuff, and have no problems with the Scat rods. Probably break one now that I've said that. <G>
