Old 07-30-2008, 10:12 PM   #8
Chad Rhodes
Default Re: Total Seal gas ported ring spacer?
Originally Posted by Jim Cimarolli View Post
R.J.
Back in 1961 there were some Mercury pickups built in Canada that had an FE engine with gas ported pistons. They were also equipped with a C-4 transmission. I would petition the NHRA for the rightfull parts that should be superceded for your car based on that truck from 1961 so that you can just run a gas ported piston instead of all those high tech expensive ring spacers.
Jim C.
you crack me up Jim
Chad Rhodes 2113 I/SA
