Old 07-30-2008, 02:47 PM   #1
Mike Pearson
Mike Pearson's Avatar
Liked 1,915 Times in 574 Posts
Default Re: C-4 Transmission Problems
Smitty,
I would put the button back on that you were using when the trans was working right. I have tried some different types of switches. If they dont realease clean it will cause the brake to act up. Did you say you are using a harrington switch. They have only a little movement until it activtes the brake. I have used this type of switch before with good results. I have a terminator button now. Jay Slane still uses the harrington switch with good results. Check your switch with an ohm meter and a volt meter to see if it is realeasing cleanly. Hope to see you a the next SSSA race.
Mike
Mike Pearson 2485 SS
Old 07-30-2008, 05:29 PM   #2
Smitty
Smitty's Avatar
Smitty,
Mike
Thanks Mike, yes I am using a Harrington switch and it seems really sensitive. I am going to do some back tracking after I come from NC and see what the issue is. I hope it is only the switch or wiring issue as I am anxious to see how I stack up against the 327. Your car looked real good this weekend from what I have heard, glad it worked out for you.
Smitty
Smitty is offline   Reply With Quote
