I have seen GM style Dizzy offered for sale for Fords......Anybody have info on such a swap???
I want to upgrade a points style dizzy in a 289 ford. |
Liked 140 Times in 51 Posts
Their is a company that makes a ford hei style that bolts right in.MSD was also working on this.I believe the company was dynavolt or something like that.They advertise in some of the hotrod mags.Good luck.
Liked 364 Times in 138 Posts
Direct fit units are available from D.U.I., (Davis Unified Ignition) http://www.performancedistributors.com/ or Proform which can be sourced from Jegs, Summit etc.
Dave Turner SS/GT #1153 |
Rather than stick a big ugly GM HEI distributor in the front of your 289, why not just retro fit a mid 70`s thru mid 80`s factory Ford DuraSpark electronic ignition? Theres only a few wires to hook up, and it works fine with either a stock ignition module or a MSD box. If you hide the module/box, it looks stock. Very reliable too. A trip to a Pick a part type wrecking yard should net you a distributor, module and wiring for less than $50.00. You can run it with either the small dist. cap, like the 289, or the later 2 piece wide cap. On a SB Ford the wide cap (and likely the converted GM HEI) often cause air cleaner interference.
Thanks for the responses... I kinda liked the GM because of the built in coil....I can buy it complete for about $50
You'd have to get a different housing and a different shaft (and gear) to get a GM HEI to plug into your Ford motor. I don't know if anyone makes a conversion kit, but I've never seen, heard, or read of any such thing.
~Pete 1970 Nova |
They sell the GM style dizzy for Fords on Ebay for less than $50...bolt in no mods!!!
Are you serious? Does it come with a module and coil and everything?
I'll bet you a beer that it has a teal blue cap and is made by ProComp Electronics in China. If that suits you, go ahead, but I much prefer stuff that's made in the USA.
~Pete 1970 Nova |
