Liked 544 Times in 213 Posts
Check the hole in the plate for elongation.........if it's worn nothing stops the bolt from moving forward and backward in the sloppy hole. You can weld a plate with a properly sized hole over the worn one and then the bolt fits tight with no slop.....
