Old 09-18-2025, 06:38 AM   #1
Fred Elsass
Liked 323 Times in 46 Posts
Default Indexing a crankshaft
Can anyone out there tell me how much HP would be gained by indexing an after market crankshaft from a reputable company?
I understand that indexing a crankshaft is to assure that each and every journal on a V8 engine is exactly 90 degrees apart.
Would this not be tantamount to attempting to build a Formula 1 engine to run Stock Eliminator?
Sarge
Fred Elsass is offline   Reply With Quote
Old 09-18-2025, 08:33 AM   #2
Billy Nees
Liked 7,916 Times in 1,757 Posts
Default Re: Indexing a crankshaft
If I needed to get a crank done from scratch, I would probably have it stroked and indexed. Otherwise, I wouldn't bother. Not for a (relatively) low HP and low RPM engine.
Billy Nees 1188 STK, SS
Billy Nees is online now   Reply With Quote
Old 09-18-2025, 11:28 AM   #3
1347
1347's Avatar
Liked 1,032 Times in 283 Posts
Take what your engine makes in hp and divide it by cubic inches, now figure out the displacement increase and plug the hp per cube into the new formula. That should give you a start. It may increase more due to the compression increase also. Thats what was explained to me many years ago by an old time.class racer.
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 09-18-2025, 04:41 PM   #4
cordoba13
cordoba13's Avatar
Liked 14 Times in 9 Posts
stock crank yes, could be up to .005 off, high quality aftermarket most likely no increase
cordoba13 is offline   Reply With Quote
Old 09-18-2025, 06:41 PM   #5
Liked 1,950 Times in 439 Posts
Sarge
Yes, INDEXING assures each rod journal is at 90 degrees (assuming we're discussing a V8).
If I bought even a relatively expensive aftermarket crank and the journals were not correctly indexed, I'd be annoyed, and return it.
If you're talking about STROKE, then, no, if I had not paid for the extra 0.014", I would not bother with it.
When you correct an OE crank, you should go for proper index first, since that relates to camshaft and ignition timing.Since you usually have to grind it to get the correct index and correct journal size, then you also go for the stroke. You often cannot approach the full 0.014" allowed while getting the index correct and maintaining decent journal size (I don't like going too small on an OE crank).
Hope that helps.
One or two crank manufacturers will make you a new crank with the 0.014" built in. Be prepared to pay through the nose, and wait until you retire before getting it.
Old 09-19-2025, 10:29 PM   #6
SS/AM
Liked 24 Times in 9 Posts
Stroking a crank for a stock or super stock is worth nothing, you're induction limited, so increasing cubic inches is pissing in the wind. Narrowing the bearings is worth something.
SS/AM is online now   Reply With Quote
Old 09-20-2025, 09:42 AM   #7
Stan Weiss
Stan Weiss's Avatar
Liked 735 Times in 386 Posts
While that maybe true at peak RPM. I can see even a small increase in both displacement and CR having an impact through out the curve.
Stan
Old 09-20-2025, 10:34 AM   #8
Liked 11,029 Times in 2,266 Posts
As my friend George would say "if it can not hurt it helps"
The crank grinder needs to have fresh or newly rebuilt indexable chucks with positive stops. Make sure the correct radius is used and fully demagnetized before insulation.
Old Yesterday, 08:50 AM   #9
Yeah, and your friend George is fast enough to make most of us look like we're sitting still.
Old Yesterday, 10:37 AM   #10
SS/AM
Stan
Read again, ALL stock and super stock combos are induction limited, your gains are theoretical and do not exist in the real world.
