Old 08-06-2025, 04:02 PM   #9
dragracerray
dragracerray's Avatar
Liked 210 Times in 91 Posts
Default Re: Notice to Numidia racers
Originally Posted by Lenny5160_v2 View Post
TrueSTART has become pretty common in bracket racing, but it will vary by track or race promoter.
When the first car leaves, the light will ALWAYS turn green. When the second car leaves, the lights will remain green if both drivers were green, or one/both red lights will turn on if either/both drivers were red. The winner will be the driver who was red by the least amount. The way it should be, IMO, although I've never heard about it being approved for use at the NHRA divisional/national level.
If you're the slower car, you just need to be sure to check for winlights after the quicker car leaves.
Lenny,
Thanks. So in the event of 2 reds in eliminations does the tree eventually show a green? If it eventually shows a green it would need to be after the last car crosses the finish line.
I think NHRA should tell the drivers before the event starts if TrueStart is being used (maybe this is a good topic for a "poll"?).
I don't know about you guys but I would drive different for TrueStart than the old way. You can not just look back and see your opponents red and know you have the win. You need to see the red in your opponents lane AND see your win light on.
Ray
Ray Bassett
I/SA 1687, SS/DA 1687
"SuperPro is both", unknown
dragracerray is offline   Reply With Quote
