Old 07-16-2025, 02:09 PM   #1
mikeloge
Liked 125 Times in 35 Posts
Default Re: Question for the old guys
i hold the record for most tear downs hands down. i dont know if they keep records but i have to hold that record i pissed somebody off i guess about 50 plus times plus record tear downs i own this one!!!!!!!!!!
mikeloge is offline   Reply With Quote
Old 07-16-2025, 03:23 PM   #2
Jack McCarthy
Liked 474 Times in 117 Posts
Ok loge is the leader and Cal is awaiting response
And in full disclosure I?ve been tossed twice 5# valve spring pressure and was last my guy ever tossed on duration cam checked 5 times till that lobe 😳😳 both times by my good friend Travis Miller
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
Old 07-16-2025, 03:32 PM   #3
Cglrcng
Cglrcng's Avatar
Liked 333 Times in 185 Posts
No record here. Only 1 voluntary mock teardown and a casting numbers ck at Englishtown, NJ in 1995 after winning class all alone and running just a hundreth under the 17.45 sea level index in GF/SA (they offered it and cc'd the head, as it had never been off since the assembly line build, car at that time
only had header and a converter).
They did find that the intake casting # was a mid-level year factory chg in October of 84 and car was a 3rd week Dec. 84 build, but Dodge never updated their (NHRA's), guide specs to include that intake for the 84 model. It took tech 22 mins. on the phone and it was verified directly from the car build sheet data.
Then they officially added to the guide officially in Feb 1996 as an accepted intake for the 99hp 135 TBI car/engine combo. Same date/ time they corrected and reduced my hp from 110 to 99 by review request letter as the only data they ever had on the single point injection TBI were all my passes.
I sat out 2.5 decades before making changes, but am fully prepared and have always carried gaskets and ck tools necessary. It will happen, and it will pass.
Sometimes positive things can and do happen. Begging someone to make a record attempt should not be necessary at the right event.
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can!
Cglrcng is offline   Reply With Quote
Old 07-16-2025, 03:38 PM   #4
Cglrcng
Cglrcng's Avatar
My bets are Loge, Method and maybe Yac.
3 times in 1 month John, sounds excessive my brother.
