Old 06-11-2025, 07:51 AM   #1
Mike Pearson
Mike Pearson's Avatar
Liked 1,988 Times in 600 Posts
Default Re: rusted engine blocks
One of the main problems with the rusted blocks is the degradation of the threads in the block, Especially the head and main bolt threads. Corrosion eats away at the threads then they pull out when the proper torque is applied. I would shy away from a severely corroded block for this reason. Blasting and chemical cleaning only removes more metal making the problem worse.
Mike Pearson 2485 SS
