Liked 9 Times in 5 Posts
Is the 904 with a Chevy bolt pattern legal in Super Stock? Being an AMC guy where they came from I just picked one up with some other 904 stuff. Don't really have a use for it but was curious if it was legal.
#2 | |
Liked 172 Times in 81 Posts
Any model transmission, same make as car, with a maximum of three forward speeds (unless OEM equipped with more than three forward speeds).
Jim Mantle U/V/SA 6632 |
Liked 5,137 Times in 1,960 Posts
They did... along with the 153 Chevy II 4 cylinder.
I guess the PG wouldn't cut it , especially around Christmas time ;-) The question would be..Is it a truck transmission (Jeep) or car.? Nobody is going to fight this one out today anyway. A Pro-trans is essentially 904 style aluminum pieces in a T 350 case. Brake , multiple gear ratios etc. Anybody that can afford a SS car can afford the Pro trans too They were used in Comp for a while but anything goes on the trans there, depending on class.
They were actually quite common in cars. Came in AMC cars with the 4 cylinder from 80 thru the end of car production in 83. Also came in 4 cylinder jeeps from 81-83. They made quite a few, but that stuff is all rotted apart now. Dunno why I picked it up; probably just a conversation piece.
#6 | |
Not being well versed in the foreign cars, that one slipped by me ;-)
Liked 886 Times in 238 Posts
Having worked for a AMC/JEEP dealership for 40 years and during 79-83, we saw very few AMC cars sold with the Iron Duke engine and an automatic trans.. Base model CJ5 Jeeps with the Iron Duke with an automatic also were few and far compared to stick shift BW SR4 transmissions.
The AM General DJ5 Postal Jeeps to my knowledge from 80-83 were all Iron Dukes with 904's behind them . I never saw one with a manual trans
Liked 239 Times in 114 Posts
The mail trucks used to come with a 153 4 cyl, and a THM 180, which is a 3 spd made in Europe, mostly for Opel. When that trans was discontinued, that is when the 904 with the Chevy bell was created. The 180 was replaced with an overdrive added on, basically a 200-4R overdrive gearset was added between the converter and the 180. That is the trans that GM sold to BMW, and the OD ratio was slightly reduced to .72 ish.
