Old 05-14-2025, 02:22 PM   #1
AveryMcLawhorn
Liked 80 Times in 19 Posts
Default 3 Speed Transmission Question
Asking an age old question but looking for some real experience and or data to back up the questions.
In terms of three speed transmissions out there for SS with trans brake what is the actual ET differences between say the following:
Protrans
Rossler TH350 Lighted
Coan XLT-350
Metric 200 (McClay or Equivalent Builder)
A-1 TH350 Lighted
ATI Transmissions
etc.
Before anyone says, I know there are a lot of variables, gear ratio, convertor, etc. but looking for some actual experience out there. I have heard pro-trans is one of if not the fastest, but by how much or was cause the gear ratio was changed to be more ideal for the combination?
Avery G. McLawhorn
2166 Super Stock
AveryMcLawhorn is offline   Reply With Quote
Old 05-14-2025, 11:02 PM   #2
Jrh5220
Liked 42 Times in 23 Posts
Smile Re: 3 Speed Transmission Question
Protrans
Coan XLT-350
A-1 TH350 Lighted
ATI Transmissions
etc.
Avery it depends on what you are changing from,a 200 turbo from a glide in a h stocker was .o12, from a 2.18 glide to a rossler was .002 slower.so your results will very. My 2 cents.
Jrh5220 is offline   Reply With Quote
Old 05-15-2025, 10:21 AM   #3
James Perrone
Liked 1,865 Times in 435 Posts
Default Re: 3 Speed Transmission Question
In super stock.pro trans was always the fastest
Rumor has it the Coan is just as fast or better now
The metric 200 stuff you don?t see a lot on the east coast
james perrone 1290 STK
Old 05-15-2025, 05:19 PM   #4
Frank Castros
Liked 2,783 Times in 981 Posts
What can Joel on Joy do to enhance a transmission. Many of the FSS cars at Charlotte had his sticker on the rear bumper.
Old 05-16-2025, 12:58 PM   #5
rsalemi
Liked 24 Times in 11 Posts
I believe Joel built the C4's for the original FS mustangs years ago.
rsalemi is offline   Reply With Quote
Old 05-16-2025, 02:07 PM   #6
jmcarter
jmcarter's Avatar
Liked 3,249 Times in 988 Posts
Whatever Marshall runs…
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 05-16-2025, 05:04 PM   #7
AveryMcLawhorn
Thanks to all that have responded so far. Agree Marshall has a fast whatever.
Wonder how much the transbrake for super stock vs a stocker transmission makes a difference in the ET times mentioned or if it would be the same across the board.
Avery G. McLawhorn
2166 Super Stock
Old 05-16-2025, 07:23 PM   #8
Liked 1,951 Times in 439 Posts
A trans brake usually requires more fluid pressure, more volume, and more friction capacity. A three speed brake is not as quick, clean, or consistent as a PowerGlide brake. As such, a three speed with a brake will almost certainly be slower than one without.
I don't know that you'll find a reliable significant difference in ET between the various three speeds, once you get into the $5,000 and up price range. Often there will be more ET advantage in optimizing your combination, meaning converter and gear ratios, than there will be in one three speed over the other.
I'd suggest you ask around and see who has the happiest customers from a service and support perspective. That might serve you best. There's also the question of the most affordable gear set options.
Old 05-16-2025, 07:33 PM   #9
SSDiv6
Cars with transmissions from Joel can have either a C-4 or a TH-400.
Joel limits the use of the Ford C-4 based on the amount of torque the engine puts out.
Old 05-18-2025, 10:04 PM   #10
GTX JOHN
We have run multiple transmissions over the past
well over 30+ years in our Mopar Stock/SS cars.
Protrans is always the fastest and most reliable for us
over the years.
John Irving
741 Stock
741 Super Stock
