#41 |
Liked 126 Times in 61 Posts
Those magic alternators that charge and discharge. I had one last year. Tom's solenoid solves the issue.
#42 |
Liked 20 Times in 16 Posts
Brilliant idea Tom!!
As usual thanks for sharing your knowledge.
Drew Wonderly SST 159 |
#43 |
Liked 11 Times in 6 Posts
An alternative to the relay to shut the power off to the alternator when in the trailer or in storage is to use a Cole Hersee P/N 75912 double pole battery disconnect switch. The main battery cable gets wired to one pair of terminals and the alternator field cable to the battery goes through the other pair.
#44 |
Liked 351 Times in 139 Posts
I run master switches in everything, motorhome, bracket car, antique, Stocker. If there is a problem, I can turn the power off at the batt. (or if it's sitting for long periods)
Also, if an alternator is drawing power while not in use, you have a diode gone. You can unhook the cable or put a master switch on it, but that is a band aid to the real problem. Further, if one of the three diodes is gone and you have a batt light, you will see it flicker or come on at idle and go out when you add throttle. This also means the alternator is not putting out as much amps as it used to with three diodes. I've never heard, and I'm trying to figure why, cutting the field wire would hurt an alternator. That is how it works, the regulator turns the charging on and off by regulating the power going to the field. It's how I test an alternator, spin it and add power to the field wire, if it charges, the problem is something else. (ford with FSAI wiring to the external regulator is mostly what I deal with) Not saying anyone is wrong, I just don't understand how it could be a problem.
Jim Miller 103 U/SA |
#45 | |
Liked 856 Times in 234 Posts
#46 |
Liked 91 Times in 51 Posts
Just spoke with tech support @ Tuff Stuff Performance which is one of the primary sources for the high output @ low rpm CS121 alternators.
He said it is unfortunately common that standard race car wiring and shutting off the master cutoff will zap the regulator. I purchased another 7937ST and it is working fantastic. Next time I have to go through a full tech, I will be removing the alternator belt. Clark Last edited by cad; 05-29-2025 at 01:20 PM. |
#47 |
Liked 487 Times in 237 Posts
QUOTE:
Not saying anyone is wrong, I just don't understand how it could be a problem. I don't think the problem is actually the "alternator" as it is the "regulator" that is getting zapped... If the alternator is putting out a high amperage and the switch is turned off, it sends a spike through the regulator which is a bunch of made in china electronics, diodes/SCR's and such. Electronic circuits don't like sudden changes in volts/amps. Back in the day the external regulators were relays and ceramic wound resistors, and while not bullet proof, could handle a lot more in the way of hard use. |
